Use the IPS system or use G76 threading cycle and just add the proper taper. All the info you need on the cycle is in the manual.
Hi everyone, I have a HAAS TL-2 and i am having some trouble programming the thread for 1/8npt and 7/16-20. I have quite a bit of knowledge setting up the machine but i am new to the programming aspect. Any tips and advice would be helpful.
http://www.kirkcon.com/
What is your problem programming G76.
