Results 1 to 5 of 5
Thread: SL30 Tool Pre-setter
    Oct 2011
    United Kingdom
    Does anyone know what the diameter of the tool presetter is on an SL30 Lathe?
    I have only been using it for setting tools in Z and using the OD of a part to set the X offset.
    It would be great if I could find out what the 2 diameters are for setting turning and boring tools in the X axis.
    Thanks.
    Nov 2005
    It sounds like you some how lost the info from when the probe was last calibrated. It shouldn't be too hard to recalibrate it, you just need to experiment a little. Probe an OD tool that you already know what the correct X offset should be. If the X offset changes .050 then change the probe setting .050 (.025?) and probe it again.
    Nov 2005
    Check out page 130 in this manual.
    http://www.haascnc.com/doclib/manual...lish_lathe.pdf
    Feb 2007
    Quote Originally Posted by djm77 View Post
    Thanks.
    This is confusing to me. Unless the parameters were lost or changed for some odd reason or the probe was replaced/crashed, you should just touch off the tools in the X axis.
    For drills, while in "Hand Jog" and on the "Tool Geometry" page with the appropriate tool offset highlighted, press "F2". It will automatically set the offset for the center line of the Bolt On block.
    For OD turning tools, touch off the top of the probe for the X axis. For ID tools, touch off the bottom of the probe for the X axis.
    There shouldn't be too much rocket science involved here. ;p
    Good luck!
    Mike
    Feb 2010
    Quote Originally Posted by gizmo_454 View Post
    Good luck!
    Mike
    Yes, you should be able to touch off just as you stated, but from time to time, the probe for various reasons needs to be recalibrated along with the tool center line (F2) feature.
    The information is in the manual.
    1. Need Help!- Tool Setter Macro for M-V60C and Metrol Setter
      By mitshack in forum Mazak, Mitsubishi, Mazatrol
      Last Post: 02-02-2013, 06:08 AM
    2. Need Help!- tool setter
      By korte1 in forum Mazak, Mitsubishi, Mazatrol
      Last Post: 12-20-2012, 11:21 AM
    3. Tool Pre Setter
      By Allen123 in forum Mach Software (ArtSoft software)
      Last Post: 03-16-2009, 12:29 AM
    4. Need Help!- Tool setter macro for M-V60C and Metrol setter
      By mitshack in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 10-06-2008, 09:38 AM
    5. tool setter
      By ACME in forum General Metalwork Discussion
      Last Post: 07-30-2005, 12:15 PM
