Results 1 to 5 of 5
Thread: Threading on ST30 problem??
    Mar 2011
    uk
    i'm doing a thread on an ST30, the thread finishes part way down a diameter (no under cut to run into).
    Do i need to run M23 code and what value for setting 95 and 96??
    i've tried running M24, but the tool comes to dead stop and creates an under cut (and looks bad!)
    any help please?
    thanks Jim
    Registered dcoupar's Avatar
    Mar 2003
    Yes, you need M23 to turn on Chamfering. It should be on by default when you turn on the machine, but if you've programmed a M24 you'll need to program M23 again.
    Setting 95 = number of "leads" to chamfer out. (0 to 29.999) I would try 1 to start.
    Setting 96 = chamfering angle. (0 to 89 degrees - no decimal point). Try 45 or 60.
    Jul 2005
    You also need to watch your rpm. If you are running too fast the machine simply cannot pull out fast enough.
    Incidentally, even though it is often done, just running a thread down a diameter and stopping with a pull out is not always the best design especially if the thread will experience a bending or cyclic load. It is always better from a fatigue resistance point of view to end a thread in a radiused undercut.
    Mar 2011
    uk
    thank you.
    i was running a bit fast (1600 rpm), i'll see how i get on in the morning!
    It's the first thread that doesn't end in an under cut on these Haas lathes.
    Incidentally, i've done threads up to 3" x 3.5 BSW without any problems.
    I'll post what happens!
    thanks again
    Mar 2011
    uk
    Quote Originally Posted by dcoupar View Post
    Excellent job!!
    ran setting 95 at 2. and setting 96 at 45, looks good, thanks for the replys
    1. ST30 - Live Tool Tapping/ThreadMilling
      By Shooter7 in forum Haas Lathes
      Last Post: 05-02-2011, 02:17 PM
    2. Need Help!- Will the SL30 Barfeed fit my NEW ST30??
      By CoolhandLuke in forum Haas Lathes
      Last Post: 04-18-2010, 03:34 PM
    3. Need Help!- G76 Threading problem
      By bmlw in forum Fanuc
      Last Post: 02-26-2010, 05:42 AM
    4. Mazak ST30
      By subalb in forum General Metal Working Machines
      Last Post: 02-14-2009, 08:07 PM
    5. threading problem
      By girishnadkarni in forum Fanuc
      Last Post: 08-29-2008, 06:22 PM
