Page 2 of 2 FirstFirst 12
Results 13 to 17 of 17
Thread: Slender pin
  1. #13
    Registered djr76's Avatar
    Nov 2007
    automation alley
    Quote Originally Posted by joe-w View Post
    here are some pic I took by phone.
    Please have a look at the flat end, That is another trouble. I machined it by live tooling(5/8 endmill), the heavy chatter damaged the cutting edge just a few pieces. I have tried rpm 3000, 2500, 2000,1500 and 500. feedrate is 0.002/tooth.
    you can do it 1st before turning while you have 1/2" stock to give it rigidity, downside is you will have some interrupted cut, but a good quality roughing insert shouldn't be phased by it. Or you can do it with 2 end mills, a rougher then a small diameter for finish after turning.
  2. #14
    May 2004
    Wow. You been working on this problem 2 days and still do not have 300 good parts finished? Should have been dropping them off the machine completed at a rate of about 20 per hour. I feel bad for ya. Good luck.
    http://www.kirkcon.com/
  3. #15
    Registered KenFoulks's Avatar
    Aug 2010
    There are more than 2 inches in the jaws.
    And What's mean of SSV?
    Thank you, Ken
    SSV is Spindle Speed Variation:
    How To: Spindle Speed Variation | Haas
    Thanks,
    Ken Foulks
  4. #16
    Sep 2011
    Quote Originally Posted by txcncman View Post
    Thank you
  • #17
    Sep 2011
    Quote Originally Posted by djr76 View Post
    Thank you djr76
  • Page 2 of 2 FirstFirst 12
