As far as I can see there is no error in your code, you have the same distances covered on both radii; Z moves -0.03, X moves 0.06 (on the diameter), both should give the same result.
One question I have is what is the tool nose radius? A rougher will have a largish radius and because you have not called tool compensation your actual radius on the work is going to be the programmed radius minus the tool nose radius.
Try changing both radii to something like 0.05.
LinkBack URL
About LinkBacks
