Results 1 to 10 of 10
Thread: Spherical Radius /Need Help
    Jun 2010
    I m trying to put a radius on the end of a handle bar Nub that goes on a Motor cycle.
    My radius is Spherical because / the Side veiw of 1.420 Dia part is 1.290 long.
    The radius starts at .290 at the end of the part( It is 1.420 Dia for 1 inch) then .290 at the end is a radius.
    If you are looking at the front view (Diameter) O.D. dim. is 1.420 then the radius stops at .875 the center is flat in that .875 circle and has a countersunk hole. here is a link to the part Left Handlebar Weight Suzuki VS800 Intruder 1998 | eBay
    I have set my Z start point away from the part .41 then .75 radius (That got it Close instead of .875 at the end it is .1145)then move those numbers up and down an can't get it right
    Any Idea's
    Registered KenFoulks's Avatar
    Aug 2010
    What kind of tool are you using? What values are you using for your cutter comp? Please post a few lines of G-code.
    Thanks,
    Ken Foulks
    Jun 2010
    Thanks for the reply
    Thanks I figured it out today.
    With help from my Instructor.
    The Diminsions I was given was not (Totally) Correct.
    With that being say /My Radius figured to be 0.300.
    Which was 0.331 with Cutter Comp in the code
    My code that worked was as follows
    T303
    G 54;
    G50 S1200;
    G96 S300 M03;
    G00 X 1.47;
    Z 0.05;
    G71 P101 Q102 U0 W0 D0.005 F0.006;
    N101 G00 X0.758;
    G01 Z0;
    N102 G03 X1.42 Z-0.331 R0.331;
    G00 X1.47 Z0.05;
    M30;
    I still have an Issue with my RPM & SFM & Feed rate when I turned the Diameter of the piece down.
    The stock is Stainless Steel (dont know what kind )
    It is 1.750 dia to be turned down to 1.420.
    I never could get it to curl off right.
    I tried all different RPMs /feeds & SFM,s and depth of cuts .015 down to .005.
    I guess I will have to buy a Machinist Calc Pro calculator.
    I got real close with Info from MHB
    but it still left real small grooves in the surface
    The bit seem to be sharp.
    Any Suggestions?
    Thanks again
    Jun 2010
    Thanks Ken I posted the Code in the Thread
    Aug 2010
    Quote Originally Posted by Getter-Done View Post
    Any Suggestions?
    Need much more information, especially the type of material. Stainless has many varieties. Answer these questions:
    Material: (303, 304...)
    Work-holding: Good (hydraulic, bored soft jaws) Bad (Manual, close diameter hard jaws)
    Machine: (SL-20, 30)
    Tool: (CNMG, VNMG, DNMG)
    Insert Grade: (4225, 4015...)
    Insert Size/Radius: (432. 431, 532...)
    Assuming the first selection of each, try 130 SFM, .085 DOC, .012 IPM
    Thanks,
    Ken Foulks
    Jun 2010
    Thank you for your time
    1st Question : This stainless is Very Magnetic
    2nd Ques : Regular 3 jaw chuck with Chuck key
    3rd Question : it is a HAAS toolroom lathe SL 6 or 9 not real sure I can Find Out.
    the rest of it I'm Guessing
    I think 432 on on Radius
    The bit holders are black in Color and made of very (hardnend) material.
    I check today about more accurrate info
    Aug 2010
    400 series stainless steels are the only stainless steels that are magnetic. Based on your problem, it does not have sulphur in it, which improves machinability. This rules out 416, leaving 410, 420, 430, 431, and 440. These materials have an average surface speed recommendation of 75 to 90 SFM. Assuming you have the smallest tool room lathe, the TL-1, it has a 7.5hp 1800RPM spindle. The most torque is available at about 50-400 RPM. Try these cutting parameters:
    75-90 SFM (160-200RPM at 1.75" dia, 200-240 at 1.42" dia)
    .035-.07 DOC (adjust this up from.035 to be more efficient)
    .012 IPM (Adjust down if you have to, to not stall spindle)
    Good Luck
    Thanks,
    Ken Foulks
    Jun 2010
    Thanks Ken
    My biggest Problem was the DOC. Is was taking .015 cuts.
    When you suggest .085 that turned on the (light bulb).
    I was taking to light of cuts.
    the Stainless Steel was 17-4 PH
    Here is the code that worked
    T303;
    G54;
    G50 S2000;
    G96 S300 M03;
    G00 X1.825;
    G00 Z0.15;
    G71 P101 Q102 U0 W0 D0.1 F0.015;
    N101 G00 X1.42;
    G01 X1.42 Z-1.325;
    N102 G01 X1.825;
    G00 X1.825 Z0.15;
    M30;
    Aug 2010
    Always take a DOC bigger than the radius of the tool.
    Thanks,
    Ken Foulks
    Jun 2010
    That is good to Know
    I can remember That
    1. How to program spherical radius
      By Javy in forum Fadal
      Last Post: 07-30-2010, 06:20 PM
    2. Need Help!- Spherical Radius - Improving suface finish
      By mkslice in forum General Metalwork Discussion
      Last Post: 06-20-2009, 02:39 AM
    3. Is this spherical design possible, & if so, how do I do it?
      By Odin in forum General Metalwork Discussion
      Last Post: 08-12-2008, 08:33 AM
    4. Spherical Mold...
      By chroniccodez in forum Moldmaking
      Last Post: 01-22-2008, 01:53 PM
    5. How can I grinding a spherical Radius on an OD
      By scmachining in forum General Metalwork Discussion
      Last Post: 11-23-2007, 03:53 PM
