Page 2 of 2 FirstFirst 12
Results 13 to 22 of 22
Thread: Need help cutting 304SS on SL-10
  1. #13
    Registered KenFoulks's Avatar
    Aug 2010
    Here is the tech info on the insert. Assuming your SL-10 has a max spindle speed of 6000 RPM, 600 SFM is max at your smallest diameter.
    Attached Thumbnails Attached Thumbnails Need help cutting 304SS on SL-10-iscar_432_807.jpg
    Thanks,
    Ken Foulks
  2. #14
    Aug 2009
    so you saying max the "clamp" rpms @ 6000 (max on sl-10) & run 600sfm?
  3. #15
    Registered littlerob's Avatar
    Jan 2008
    600 SFM at .687 Diameter is NOT 6000 RPM it is 3335. Did I miss something?
    The beaten path, is exclusively for beaten men.
  4. #16
    Aug 2010
    Quote Originally Posted by patnok View Post
    Starting dia. is .6875. finish dia. is .372. turning down 2" 304ss
    .372 is the smallest diameter, at that size at max RPM is 600 SFM.
    Thanks,
    Ken Foulks
  • #17
    Aug 2009
    Cool
    I should have confessed that I am/was a mill guy. I'm still trying to wrap my head around this surface feed (S###) & and it's relation to feed rate (F.00##). My main issue is breaking the chips. I'm getting about 100-120pcs per $5 insert now (the iscar is what $20?). That's ok. The razor wire I could do without.
    thanks for the input I'm gonna try that 6grand stuff tomorrow.
  • #18
    Jan 2008
    You're right my fault I missed that.
  • #19
    Apr 2005
    Paradise, Ca, USA
    You should be programming in inches per revolution (IPR), so feedrate stays constant no matter the RPM. It only looks like it's feeding faster as SFM goes up.
    Maybe using $5 inserts is part of your problem. Do you use $10 1/2" endmills in the mills?
  • #20
    Aug 2009
    Cool
    The high dollar iscar fared no better. so I figured if i'm gonna burn up inserts they're gonna be the cheap ones! almost done with this batch. I'll school up some more before the next. Thanks for all the input on this & my next post will be how to.........
  • #21
    Aug 2009
    Cool
    deeper cut was the trick, if it's not making chips it's making a curly-cue that is nothing like the razor wire i was getting. did test runs with different inserts & the cheapos last almost as long as the iscar. I'll crank it up to 600sfm tomorrow afternoon as a test. then 5 days off!
  • #22
    Jun 2008
    Throw one of these in to the mix and see how it does.
    MSC Item Detail
    D.04 - .06
    F.014 - F.018
    SFM 550-650
    That should be about the limits of the SL10 spindle so...
    For reference, in Our machine (30hp spindle).
    We run these at
    650SFM
    F .018-.021
    D .06-.08
    and thats in 15-5PH SS
    Van Fleet Precision Machining
    http://www.vanfleetprecision.com/
  • Page 2 of 2 FirstFirst 12
    1. Feeds/speeds, etc for 304ss
      By edge540 in forum General Metalwork Discussion
      Last Post: 07-30-2010, 12:01 AM
    2. Demag annealing of 304ss
      By naytep in forum General Material Machining Solutions
      Last Post: 04-03-2008, 06:07 PM
    3. Demag annealing of 304ss
      By naytep in forum General Metalwork Discussion
      Last Post: 04-03-2008, 06:01 PM
    4. Drilling 304SS
      By TT350 in forum General Metalwork Discussion
      Last Post: 11-27-2007, 08:41 AM
    5. :RFQ: 2 304SS Flanges
      By CarTunr22 in forum Employment Opportunity
      Last Post: 03-05-2007, 10:48 PM
