Results 1 to 3 of 3
Thread: Bar Feed Interface
    Registered rrbmachining's Avatar
    Mar 2007
    United Kingdom
    Bar Feed Interface
    Does anyone know how easy it is to fit a barfeed interface to a SL20. I have been offered a three year old Haas Barfeed and the owner wants to remove the interface from his SL20 and I am looking to fit it to mine
    Jan 2011
    Used bar-feeder
    Be careful on the age of the barfeeder.
    There were several different versions and your lathe may not work with what you found.
    Older bar-feeders came with a standalone servo control box in the bar-feeder.
    The newer ones use brushless motors and the CNC drive the bar-feeder motor directly.
    If your lathe is already brushless, that's the easiest way to go.
    If the old bar-feeder comes with lots of docs, this might work.
    Otherwise you may need to talk to your dealer.
    Mar 2007
    United Kingdom
    Thanks for that, the machine I am putting it on is only just over a year old and one of the last SL20 made, the feeder was made in 2007 so hopefully it should not be a problem
  1. Need Help!- cnc interface
    By gabrielmrc in forum Stepper Motors and Drives
    Last Post: 01-05-2011, 09:09 AM
  2. Okuma mill feed rate jumps to rapid feed
    By easyguy97 in forum Okuma
    Last Post: 12-20-2009, 05:14 AM
  3. best lpt interface need
    By chawkiz in forum Open Source Controller Boards
    Last Post: 03-28-2009, 09:04 AM
  4. X2 w/ V9 interface
    By millcat in forum Mastercam
    Last Post: 10-04-2007, 01:17 PM
  5. My new interface...
    By murphy625 in forum CamSoft Products
    Last Post: 04-15-2005, 06:27 PM
