Results 1 to 5 of 5
Thread: Z Axis can't find home
    Mar 2006
    We started our TL-3 lathe this morning and it can't find it's home position.Moves slowly looking for home it seems. With the machine on when you turn the z axis hand wheel it turns for a bit and then comes to a stop like I've hit a solid stop but with the machine off you can crank it all the way to the chuck and all the way to the tailstock with no problems.Could this be a limit or proximity switch? And where would they be located I don't see either anywhere.
    Dave
    Registered Donkey Hotey's Avatar
    Nov 2007
    I believe you're looking for a proximity sensor and I believe it's on the back of the casting, on the back, right side (tailstock end). It should be pretty obvious.
    From what has been posted here in the past, you probably have a wayward chip in there that's fooling the sensor.
    Greg
    Jan 2007
    Ca
    What alarm are you getting? You are correct in the location of the z axis home switch.
    Mar 2006
    no alarm,it's just looking for home.It's going in the wrong direction too.It seems if I were to let it go it would hit the chuck.
    Mar 2006
    I found the proximity sensor,on this machine (TL-3) it's located towards the back under the carriage (if you remove a cover between the bed casting it's a little easier to see) and the tab that makes contact with it is at the back right of the tailstock.Blew it out and that was the problem.Took 5 hours to find it 5 minutes to fix it.
    Dave
    1. Need Help!- ACU RITE CONTROL ERROR FTO'S FIND HOME FAULT
      By jstwinbaby in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 02-15-2010, 12:41 PM
    2. Need Help!- Probe macro to find flat on A axis
      By metlshpr in forum Haas Mills
      Last Post: 06-30-2009, 08:30 AM
    3. Looking to find a home for a Bridgeport Series 1 CNC (was BOSS 5, now Mach3)
      By bbuonomo in forum Bridgeport and Hardinge Mills
      Last Post: 02-20-2009, 08:35 AM
    4. TL2 Would Not Find Home Position
      By Geof in forum Haas Lathes
      Last Post: 01-24-2008, 10:21 PM
    5. Where to find a good VH65 4th axis?
      By carbidecraters in forum Fadal
      Last Post: 09-14-2007, 01:00 AM
