Results 1 to 3 of 3
Thread: Haas SL20 C Axis Fault
    Oct 2006
    Anyone had experience with a C Axis Fault on a Hass SL20?? Potential motor, drive, or cable problem?? It has been progressive issue on start up. Originally I could get through power up after several attempts and it would run all day. Now it won't complete the powerup without a C axis fault. Any thoughts on where to start looking?? I've called Hass tech support to disable the c axis so I could continue working but now I need to get it running.
    Any ideas would be appreciated.
    Feb 2010
    What is the alarm number that you are getting? Does it happen when trying to home the machine? If not, then when do you get the alarm?
    Oct 2006
    I don't recall the alarm number but it happened at power-up (home cycle). I currently have the C axis disabled because I need to cut other parts.
  1. HAAS SL20 and HAAS VF2 ProE Posts?
    By CNC_student in forum Post Processor Files
    Last Post: 11-29-2012, 05:48 AM
  2. Problem- Haas sl20 2005
    By ashro in forum Haas Lathes
    Last Post: 03-11-2010, 11:32 AM
  3. Haas SL20
    By rickkiefe in forum Haas Mills
    Last Post: 10-19-2009, 12:52 PM
  4. MQL in Haas SL20 ?
    By Sachn in forum Haas Lathes
    Last Post: 09-09-2009, 09:22 AM
  5. haas sl20
    Last Post: 07-24-2009, 08:52 AM
