Results 1 to 2 of 2
Thread: Turning with different radius
    Apr 2010
    I am trying to turn the OD with one final pass. I am using a SL-30 Haas Lathe and the tool is a .375 diameter round insert (Kennametal RD8P). See attached file.
    Attached Thumbnails Attached Thumbnails Turning with different radius-haas_part.jpg
    Aug 2009
    You didn't post a question. What is it about this you need help with? If it's the code send me the dxf and I'll send it to you.
  1. Need Help!- Pinch turning or Balanced turning
    By pradeep in forum Mori lathes
    Last Post: 09-07-2010, 02:55 PM
  2. Need Help!- Radius to end of Arc Differs From Radius to Startline
    By Bob La Londe in forum Machines running Mach Software
    Last Post: 08-09-2010, 10:16 PM
  3. Problem- Vinyl-optimized CAM softw? To compensate for blade orientation, turning radius etc?
    By FXC in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 02-25-2010, 06:59 PM
  4. Replies: 8
    Last Post: 11-15-2009, 07:35 AM
  5. Need Help!- Radius to end of arc differs from radius to start?
    By Jamy in forum LinuxCNC (formerly EMC2)
    Last Post: 08-23-2009, 12:28 AM
