Results 1 to 3 of 3
Thread: 3" NPT
    Feb 2010
    3" NPT
    Haas SL20 question
    What would the code look like to cut 3" NPT in Aluminum? The piece I am working on needs thread on the chucked side of the part, so I need to reach thru the part to cut them.
    Any help would be great!
    Aug 2009
    If you want the exact code I need more info. 8 tpi? Id or od threads. Longhand using g32 or caned cycle using g76. I used g76, 8tpi, od threads, and the threads on the chucked side as you stated and came up with this:
    G76 X2.7372 Z-1.75 I0.0547 K0.0767 D0.015 A30 E0.125
    longhand using g32 would look like this:
    X3.05
    X2.9705
    G32 X2.8611 Z-1.7484 E0.125
    G00 X3.05
    Z-0.0019
    X2.9583
    G32 X2.8489 Z-1.7519 E0.125
    G00 X3.05
    Z0.0008
    X2.9489
    G32 X2.8395 Z-1.7492 E0.125
    G00 X3.05
    Z-0.0014
    X2.941
    G32 X2.8316 Z-1.7514 E0.125
    G00 X3.05
    Z0.0005
    X2.934
    G32 X2.8246 Z-1.7495 E0.125
    G00 X3.05
    Z-0.0013
    X2.9277
    G32 X2.8183 Z-1.7513 E0.125
    G00 X3.05
    Z0.0004
    X2.9219
    G32 X2.8125 Z-1.7496 E0.125
    G00 X3.05
    Z-0.0011
    X2.9165
    G32 X2.8072 Z-1.7511 E0.125
    G00 X3.05
    Z0.0003
    X2.9115
    G32 X2.8021 Z-1.7497 E0.125
    G00 X3.05
    Z-0.0011
    X2.9067
    G32 X2.7973 Z-1.7511 E0.125
    G00 X3.05
    Z0.0002
    X2.9021
    G32 X2.7927 Z-1.7498 E0.125
    G00 X3.05
    Z-0.001
    X2.8978
    G32 X2.7884 Z-1.751 E0.125
    G00 X3.05
    Z0.0002
    X2.8936
    G32 X2.7842 Z-1.7498 E0.125
    G00 X3.05
    Z-0.001
    X2.8896
    G32 X2.7802 Z-1.751 E0.125
    G00 X3.05
    Z0.0001
    X2.8857
    G32 X2.7763 Z-1.7499 E0.125
    G00 X3.05
    Z-0.0009
    X2.882
    G32 X2.7726 Z-1.7509 E0.125
    G00 X3.05
    Z0.0001
    X2.8783
    G32 X2.7689 Z-1.7499 E0.125
    G00 X3.05
    Z-0.0009
    X2.8748
    G32 X2.7654 Z-1.7509 E0.125
    G00 X3.05
    Z0.0001
    X2.8714
    G32 X2.762 Z-1.7499 E0.125
    G00 X3.05
    Z-0.0009
    X2.868
    G32 X2.7586 Z-1.7509 E0.125
    G00 X3.05
    Z0.0001
    X2.8648
    G32 X2.7554 Z-1.7499 E0.125
    G00 X3.05
    Z-0.0008
    X2.8616
    G32 X2.7522 Z-1.7508 E0.125
    G00 X3.05
    Z0.
    X2.8585
    G32 X2.7491 Z-1.75 E0.125
    G00 X3.05
    Z-0.0008
    X2.8554
    G32 X2.746 Z-1.7508 E0.125
    G00 X3.05
    Z0.
    X2.8524
    G32 X2.7431 Z-1.75 E0.125
    G00 X3.05
    Z-0.0008
    X2.8495
    G32 X2.7401 Z-1.7508 E0.125
    G00 X3.05
    Z0.
    X2.8466
    G32 X2.7373 Z-1.75 E0.125
    G00 X3.05
    Just so you know, I did not create any of that code by hand, I used cam software.
    Feb 2010
    3" NPT - 8 tpi internal threads
    Thanks for the post.
    The part needs 3" NPT - 8 tpi, these are internal threads. As I look at the machine, I am chucking on the left side of the part and the threads need to be on the inside on the left side of the part. Make sense? The threads are not on the face of the part, but on the back side.
  1. Replies: 12
    Last Post: 06-27-2012, 07:30 AM
  2. Need Help!- Thread Milling using "C" axis no "Y" on the machine
    By tejano4life72 in forum Mori lathes
    Last Post: 07-19-2010, 03:59 PM
  3. Need Help!- "motor steps per resolution" and "driver microstepping" settings
    By margni74 in forum LinuxCNC (formerly EMC2)
    Last Post: 10-24-2009, 03:33 AM
  4. "J" head type "millport"(tiwan,1980) clutch
    By marksbug in forum Bridgeport and Hardinge Mills
    Last Post: 08-17-2009, 11:48 AM
  5. Need Help!- "Warco GH Univ" V "Chester Lux Mill"
    By JQ_Quint in forum Benchtop Machines
    Last Post: 01-22-2009, 11:59 AM
