This is the alarm description:
Alarm 744 Sp AXIS Z CH MISSING
Z reference signal from encoder was not received as expected. Can be
caused by loose connections, encoder contamination, or parameter error.
You should check the connections first.
Are you sure about the software version as the highest we have in the five series is 5.07.
LinkBack URL
About LinkBacks
