Results 1 to 3 of 3
Thread: Parametric programing
    Apr 2010
    I would like to streamline a program on our HAAS SL30. I have a predefined path I need to follow repeatedly that varies based on two parameters. Can anyone send/write me a short example of a subroutine that accepts parameters and how to call it?
    I get error messages when I attempt to pass parameters to my subroutine.
    TIA
    Registered Donkey Hotey's Avatar
    Nov 2007
    Do you have the Macros option and is it enabled?
    Greg
    Apr 2005
    Paradise, Ca, USA
    Local or external sub? If you're using one, try the other. I don't know if it will work, but it's an easy thing to try.
  1. Autodesk Parametric
    By Jon83 in forum Autodesk Software (Autocad, Inventor etc)
    Last Post: 03-17-2010, 06:43 AM
  2. New to Parametric Programming
    By weaston in forum G-Code Programing
    Last Post: 02-27-2007, 08:40 AM
  3. Can you use parametric programing similar to....
    By Darc in forum Mach Software (ArtSoft software)
    Last Post: 02-14-2007, 04:55 PM
  4. Parametric Programming
    By widgitmaster in forum BobCad-Cam
    Last Post: 05-04-2006, 02:04 PM
  5. parametric programming
    By Karl_T in forum CamSoft Products
    Last Post: 05-24-2005, 03:58 PM
