Results 1 to 2 of 2
Thread: Acme thread blunt start
    Aug 2009
    Looking for help in writing a program for blunt starting a 2-1/2 6 stub acme external thread. I have a Haas TL2 and think that doing this might include changing a setting. Any tips would be appreciated. Thanks
    Registered WOLOG's Avatar
    Oct 2003
    HOUMA,LA
    All you have to do is copy the threading cycle, change the Z length, slow your RPMs down, and make sure M24 is active. I like to use a groove/turn tool that is at least as wide as the base of the thread. You may have to change the z start position a little to make sure the groove tool splits the thread. Do a test part. The biggest problem I see with the TL-2 is that the TL-2 does not rapid fast enough. That is the reason why I will slow down to 150 Rpms or less to do a thread clip. If you have problems, post the code and I will fix it for you.
  1. Acme thread 1/2-8 (8 start or 2)
    By rmubaja in forum Linear and Rotary Motion
    Last Post: 12-02-2009, 10:14 PM
  2. acme thread combos and thread mixing
    By calaber40 in forum Linear and Rotary Motion
    Last Post: 05-15-2009, 09:04 PM
  3. Blunt Start theards
    By DryRun in forum G-Code Programing
    Last Post: 11-25-2008, 08:59 AM
  4. Acme Internal Thread 1 ½ - 0.250P-2.000L-ACME-2G-LH (8 START) Help
    By pandiyan.innova in forum CNCzone Club House
    Last Post: 11-16-2006, 06:47 AM
  5. Blunt start threads
    By HPT in forum General Metalwork Discussion
    Last Post: 05-14-2006, 10:40 AM
