Results 1 to 4 of 4
Thread: New "Special series" lathes from Haas, Which turret to order?
    May 2008
    I've been looking at purchasing a lathe for several months and now Haas has just released a new "special series" lathes.
    It looks like the ST-20 has 15" max. cutting diameter but at the bottom of the specs. page it states confusing data.
    It states:
    Max diameter varies with turret. VB=12" (305 mm); VDI=9" (229 mm).
    http://www.haascnc.com/details.asp?I...LatheTreeModel
    What would be the correct turret to order to cut 15" O.D.?
    Registered Xenomorph's Avatar
    Mar 2009
    The standard BOT turret is 15" and the optional turrets are as stated.
    May 2008
    Quote Originally Posted by Xenomorph View Post
    Thanks!
    Do you know if this can be ordered with a 16C collet closer? I see 5C listed but no mention of 16C.
    Mar 2009
    I do not know. You might call Haas directly and ask them.
  1. "Gross Postioning Error A" Doing M03 on Bridgeport Interact Series 1 Mk2
    By MeTri in forum Bridgeport and Hardinge Mills
    Last Post: 12-28-2009, 12:37 AM
  2. CNC conversions of "mini" Lathes
    By g29cc in forum Mini Lathe
    Last Post: 08-15-2008, 07:34 AM
  3. How to order 4.5"X4.5"X10' steel
    By Shotout in forum General Material Machining Solutions
    Last Post: 10-02-2007, 09:24 AM
  4. Fanuc 18t Turret alarm "1110"
    By senna95 in forum Fanuc
    Last Post: 10-18-2006, 12:03 PM
  5. Bridgeport Series "I" will not home, please help technical school in need!!
    By phantomcow2 in forum Bridgeport and Hardinge Mills
    Last Post: 12-15-2005, 06:11 PM
