Results 1 to 5 of 5
Thread: Metric thread repair - TL2?
    Mar 2008
    I've been using a TL2 for a while now. I'm familiar with the thread repair function in VQC, having used it for a variety of jobs - even tapered threads have come out well. Today is the first time that I've needed it for a metric thread, and I'm not sure I can make it work!?
    I've cut metric threads using the normal "OD threading" cycle in VQC. All the numbers have to be entered in imperial - no problem. But using the "OD thread repair" function I'm forced to pick my "TPI" from a list. Metric pitches are not available! Help!
    Mar 2010
    South Africa
    reply to threads
    to convert T.P.I. to metric pitch you divide your number of threads per inch into 24.4mm because 1 inch =25.4mm.
    e.g. 8 T.P.I. =25.4 divided by 8
    =3.175mm pitch
    Mar 2008
    Quote Originally Posted by flick View Post
    I've restated with emphasis for clarification. Yes, I know that 1"=25.4mm. That's not the problem.
    Mar 2010
    South Africa
    metric thread
    sorry for misunderstanding your question,i apologise
    perhaps you could change setting 9(dimensioning) to metric and see if this helps.
    Mar 2008
    Works
    TYVM for your help
    1. Metric thread cutting?
      By machinist360 in forum General Metalwork Discussion
      Last Post: 03-09-2010, 04:28 PM
    2. metric thread
      By riverracer in forum Haas Visual Quick Code
      Last Post: 03-09-2010, 04:01 PM
    3. Need Help!- repair thread on TL-3
      By alain aleman in forum Haas Lathes
      Last Post: 03-09-2010, 03:46 PM
    4. Metric Thread On LM8x14
      By pzzamakr1980 in forum Mini Lathe
      Last Post: 06-04-2008, 09:02 AM
    5. metric thread cutting
      By toolmaker_79 in forum G-Code Programing
      Last Post: 09-03-2007, 07:11 AM
