Results 1 to 6 of 6
Thread: How to pick up G54 Offset, and Door interlock bypass ?s.
    Jul 2007
    What is procedure of pick up the Work Offset, and how do I bypass the door interlock on a SL 20?
    Thanks.
    Oct 2003
    If you have a tool probe. Set the tool offset with the probe, then jog the tool you set to the face of the stock and hit z face measure. You should get a negative number that's close to the distance from the probe to the stock.
    Setting 51 is for the door override.
    Feb 2008
    Exclamation You shouldn't - Grin
    If setting 51 is to much hassel do what I (err...somebody I know did) take a thin piece of sheet metal and bend up a little cap that clips over the prox. sensor. I (err.. "He") just takes it on and off as needed.
    Steve
    Jul 2007
    I don't have a probe setter. I'm using the Z measure, but what if I have 0.1 more to take off. The way I'm doing it now is, I touch the part, hit Z measure, then enter 0.1 to set my G54 Offset. Is there a fast way?
    And how do I Set 51?
    Thanks.
    Feb 2008
    Smile
    Quote Originally Posted by Stampede View Post
    Thanks.
    Under Settings press seting/graph … use the page up and page down to fine param 51. It is automatically set to ‘Off’ which stops the program and spindle each time the machine is powered up, so you will have to change it to ‘on’ every time. A pain, that’s why I use (uuuh… this friend ) uses the metal clip on at times. The instructions for settings are on page 167 of the 96-8700 rev P Jan. 2007 manual. The instructions for touching off the tools are on page 32. Hints: your touching off the back side of the tool with a .001 shim, and jogging over to position. Just under the power/up/restart button is the and the f3 is x/z jog button. The jog speeds are to the right side of the control panel by 'hand Jog'.0001, .001, .01 ,.1 be careful. Also lastly after touching off with a shim (or turning a cut by hand jogging) the “x dia” button is pressed and you enter minus sign and the diameter.
    Steve
    PS.. get the manual if you don't have one...
    Oct 2003
    You don't need to use the g54 work offset then. Just leave it zero and touch all your tools to the face of the stock.
    You could touch the turning tool off then subtract like .020 in z then face the part off and touch all the other tools off from the finished face.
    setting 51 is either on or off. just go to settings page ender 51 and hit down arrow and it will jump to setting 51.
    1. Please help-door interlock
      By em322 in forum Okuma
      Last Post: 01-19-2010, 03:54 PM
    2. Door interlock bypass?
      By gearsoup in forum Mori Seiki Mills
      Last Post: 12-09-2008, 01:25 AM
    3. Door Interlock override ? 18i-TB
      By YARKONE in forum Fanuc
      Last Post: 06-22-2008, 09:11 PM
    4. Door Interlock
      By hatchmar in forum Fanuc
      Last Post: 12-29-2007, 07:52 PM
    5. Door interlock?
      By Edster in forum Fadal
      Last Post: 04-05-2006, 06:13 PM
