Need Help! Replacing a Haas Monitor - Page 3
Page 3 of 3 FirstFirst 123
Results 41 to 56 of 56
Thread: Replacing a Haas Monitor
  1. #41
    Nov 2012
    Default LCD replacement for VF3 CRT Haas
    Here are two videos of the LCD replacement we found for the Haas VF3 CRT.
    More information to come as it develops.
    DL Hodgdon
    H. H. Mercer, Inc.
    H. H. Mercer, Inc. Machine Shop Birchwood Casey hhmercer
  2. #42
    Nov 2012
    Default Converson Done
    This conversion was done a Haas VF3 that had a failed CRT
    Removed old CRT.
    *** NOTE - DANGER - Warning Will Robinson !!!!!!!!
    MAKE SURE YOU DISCHARGE THE FLYBACK AND CAPS ON THE CRT BEFORE DISASSEMBLY.
    GOOGLE CRT HIGH VOLTAGE TO SEE HOW TO DO THIS.
    *** Take this warning seriously less you wet your pants and learn what a defibulator feels like.
    Be careful to not break the CRT iteself.
    EVERYTHING can be unscrewed and the whole CRT assembly can be seperated from the frame.
    Removed CRT and all CRT electronics from CAD plated CRT Frame.
    We saved the CRT and electronics in case we needed them.
    LCD has a normal screen on it and is not protected from the elements.
    We made our own screen protector.
    Made a sacraficial lens/screen protector from 0.093" acrylic.
    Cut screen protector on laser.
    Put 0.093" holes in screen protector to allow a pencile to pass through so that the operator could press the monitor buttons on the face of the monitor.
    Burned these through with the CO2 laser.
    Made a backing plate out of the old monitor bracket.
    Made some aluminum stand offs.
    Threaded both ends of stand offs.
    Placed screen protector against panel face.
    Used stand offs to screw screen protector to panel face.
    Put monitor against screen protector.
    Shimmed the face of the monitor to keep screen protector from pressing function buttons on LCD.
    Put backing plate on outside of monitor and sandwitched everything together.
    Plugged in 12v power supply to 110VAC power cord in cabinet
    Plugged in 9 pin DIN connector and extension cable to 9 pin DIN video supply.
    Powered on monitor and machine.
    Set monitor using auto adjustments
    Put Cover back on machine
    Make parts.
    DL Hodgdon
  3. #43
    S.N.A.F.U. miljnor's Avatar
    Jan 2005
    very nicely done!
    thanks
    Michael T.
    "If you don't stand for something, chances are, you'll fall for anything!"
  4. #44
    Feb 2010
    tagtech,
    End result looks great, nice job!
    So what was the monitor that you used? You mentioned that it is not a typical LCD.
    Purchased from?
  5. #45
    Sep 2009
    England
    We have an exact replacement LCD for Haas CNC 12" CRT's.
    The price is $600 plus FedEx 48 hour shipping from England, total $680.
    Email for more info: re.vision@btinternet.com
    www.cncmonitor.com
  6. #46
    Jan 2005
    Funny how all the monitors for cheap disappeared after this thread started going way back when. cheapest I've found em for now is 375-450.00 but alot of people want like 600-1200 for em. lol can buy a 17" for like less than a hundred too.
    thanks
    Michael T.
  7. #47
    Jun 2008
    Finland
    Have anybody tried this:
    12.1" CNC Replacement LCD Display with built-in MDA/CGA/EGA/RGB Video Converter
    Any ideas if it might work?
  8. #48
    May 2012
    Default Re: Replacing a Haas Monitor
  9. #49
    Oct 2014
    Springfield
    I know this tread is old but i did a conversion on my old VF3 that worked great and is still going strong..heres a video from the site
    For Sale: The computer components you just searched for!
    I don't remember what it cost but $250 sounds right?
    It was plug and play only thing was i used Velcro to attach it in the back but u can make your own brackets if you wanted
  10. #50
    Feb 2009
    Just replaced the monitor in my 2000 TM-1 with one I found on ebay. There aren't anymore listed at the moment but it came from these guys:
    LT12B-TTL, Miracle 12" LCD Monitor, 9-Pin TTL Supports MDA (Monochrome Mono) / CGA/ EGA Systems
    The cost was about $350 with shipping, which is honestly about the best deal out there for a nearly drop in replacement. You can possibly do it a bit cheaper with an MDA to VGA signal converters for about $200 and then use a regular VGA LCD, but then it's not that easy to find 12" 4:3 aspect ratio LCDs anymore. So it's worth just getting the all in one solution.
    There are other LCDs out there that will work if you search around. The important thing is that it supports the MDA graphics mode and has a 9pin connector. The 12" size is a perfect fit for my TM-1.
    I made up some simple brackets for mounting and have attached a STEP model to this post, in case anyone can use them in the future.
    C|
    Attached Thumbnails Attached Thumbnails Replacing a Haas Monitor-img_20170127_190656-jpg   Replacing a Haas Monitor-img_20170127_190302-jpg
    Attached Files Attached Files
  11. #51
    Jul 2004
    Pretty much the same replacement I did. This was for a haas 0E. I used to a monitor from computer fusion in Euless Texas because it was local to me and I was in a rush to get the machine back up. Haas replacement was about $800 or $900. Monitor was $449. Like you said pretty much a drop in replacement had a fab a couple of brackets out of some old lexan I had laying around.
  12. #52
    Jul 2004
  13. #53
    Jul 2004
    Let's see if photos attached this time.🤔
    Attached Thumbnails Attached Thumbnails Replacing a Haas Monitor-img_4039-jpg   Replacing a Haas Monitor-img_4040-jpg   Replacing a Haas Monitor-img_4045-jpg   Replacing a Haas Monitor-img_4050-jpg
    Replacing a Haas Monitor-img_4051-jpg
  14. #54
    Mar 2014
    Haas has updated a retro fit kit to replace your CRT monitors. 93-5222 is the retrofit part number.
  15. #55
    May 2012
    Our price $599.00USD + Shipping
  16. #56
    Member elongshine2019's Avatar
    Dec 2019
    HAAS CRT Monitor 28HM-NM4 is one of HAAS 12 inch CRT mono monitor displays for CNC. It was fitted on the Haas old VF-1, VF-2, V-F3, VF-4, VF-6 system, Model is: 93-5220C, 93-5220, 93-5222, 93-5222A. Signal Input Connector: 9 pin D-sub connector.
    https://en.elongshine.com/product-detail/haas-monitor/
    ELONGSHINE tech ltd are the CNC machine tool monitor replacement specialists - save up to 75% on O.E.M. prices. Fanuc, Siemens, Mitsubishi, Mazak, Magnetek, Toshiba, Hitachi, Heidenhain, HAAS, Yasnac & most other old EGA CGA MDA monitor.
    we are the manufacturer, more info at en.elongshine.com
    Attached Thumbnails Attached Thumbnails Replacing a Haas Monitor-haas-28hm-nm4_01-jpg   Replacing a Haas Monitor-haas-28hm-nm4_03-jpg   Replacing a Haas Monitor-haas-28hm-nm4_06-jpg
