Bumping back to top to see if there has been any progress. I have quite a bit of burn in on my monitor and a couple of old LCD's sitting around begging to be used.
Steve
I installed the LCD monitor on my old HAAS and it works like a charm. How much more progress do you need?
If one of your old LCD monitors has a 9 pin connector, then just plug it in, power it up, and check if you can see something on the screen. It is that simple. I tried to use a newer monitor with a 15 to 9 converter cable, and it was a no go.
chances are you need to convert the signal from 9pin ttl to 15pin vga for the lcd.....Don't know if anyone makes one...that company above selling the lcd monitor for the haas probably does the work for you.
just a guess though.
thanks
Michael T.
"If you don't stand for something, chances are, you'll fall for anything!"
Sorry, I should have been more specific. I am checking to see if any of the converters mentioned in the beginning of the post worked. I know the Haas is an MGA/TTL signal. I just wanted to know if some of the OP's came up with a converter solution.
The looking around that I did kept leading me to the Jammaboard. Here is a link to get a description.
http://www.ebay.com/itm/jamma-arcade...item3a6741de4c
Has anyone tried it out to see if it works? I have a perfectly good 15 inch LCD sitting here that I would love to put on my Haas. I mainly want to get rid of the burn in on my display. I know that an LCD screen is commercially available, I just can't justify the cost unless mine totally quits and I have no other choice.
Steve
[QUOTE=autotechsteve;1044919]Sorry, I should have been more specific. I am checking to see if any of the converters mentioned in the beginning of the post worked. I know the Haas is an MGA/TTL signal. I just wanted to know if some of the OP's came up with a converter solution.
I see your point. But is it worth to d_ck around for not that much money? Saving tons of dough by not going with the HAAS replacement and going with no brainer solution is the way to go. Now I have a nice set-up and time to go sailing.
But if you have lots of time and enjoy playing with a new idea, then that's a different story. Good luck and have fun.
For me it is worth it, and for many others I assume. You mentioned that you spent $375 for the new LCD. The adapter is $35. As for the monitor, most of us, myself included, have one laying around. If not cheap monitors are everywhere, even new. So for a little digging and trial and error, to save $340, I'll take that.
Steve
I'm thinking of getting that board just to check and see...but I'm busy at the moment...will try it next month if I can.
thanks
Michael T.
Very true but my monitor still works, I just want a screen without burn in and possibly a larger screen as well. I would like to keep this thread on topic and not about why its better to buy a drop in monitor. Converting to an off the shelf LCD is the reason the thread was started in the first place.
Steve
Just to let everyone know I bought a new CRT from Haas in November of 2011 for my 2001 VF2 and as of today it is already stopped working in less then 6 months. They have a 90 day warranty with no exceptions $500 down the drain. I looked at the tube on the CRT and it has a 1 inch crack up from the center.
I found out today that not only did the monitor go bad after 5 months but it took out the video board as well.
Reviving this thread again, but with a twist.
Has anybody replaced their CRT or even better convert to LCD who is running the Renishaw visual quick code?
Here is my scenerio:
Upgrading an 01 vintage machine with monochrome CRT to utilize visual quick code probe system; Renishaw.
The only problem I am having is the graphics for the VCQPS do not display the vertical lines of the graphics properly which makes it impossible to determine what you are looking at. All text and g-code is visually fine though.
After much troubleshooting, I have confirmed that the replacement CRT from Haas has this effect, but much older CRT's (as in original) display the graphic just fine. This is not a video PCB problem either, tried that.
So I am looking for a newer CRT or LCD conversion that is displaying the graphics of the Renishaw cycles properly. Anyone?
Well If you need the probe to work I have redone the probe code to make it work on a 1995 VF-2 without VQC. I also made a quick code file to go with it.
Thanks for the offer, but the code works just fine. The problem is that unless you have the routines memorized for what information to fill out on the screen, the operator does not know what to input.
This system is in place on about 8 other machines (all newer) and I am trying to get this one to be similar. As we all know, some operators need all the help they can get! If it is to difficult, I am certain I will be replacing damaged probes for sure.
LCD monitor conversion sucessful - installed and working on 11-11-2012!
More information to come as we proceed with this project.
DL Hodgdon
H. H. Mercer, Inc.
H. H. Mercer, Inc. Machine Shop Birchwood Casey hhmercer
cad@hhmercer.com
