Problem HAAS Tool Probe
Results 1 to 7 of 7
Thread: HAAS Tool Probe
    Mar 2010
    Default HAAS Tool Probe
    Does the HAAS Mill WIPS tool probe know where it is mounted in relation to the bed or do you have to jog to the tool probe prior to beginning?
    I have watched the HAAS Tip Of The Day and it looks like it is automated but when I try it in class it doesn't move to the tool probe.
    Member Machineit's Avatar
    Mar 2010
    Default Re: HAAS Tool Probe
    It knows where X,Y,Z zero is in relation to itself, but it has no clue to where you want it to go or where your part is.
    Two Haas VF-2's, Haas HA5C, Haas HRT-9, Hardinge CHNC 1, Bother HS-300 Wire EDM, BobCAD V23, BobCAD V28
    Mar 2010
    My question stemmed from the Tool Offsets Explained – Haas Automation Tip of the Day. Around the 8 minute mark when he starts the probe cycle the machine Z raises then travels on X to the tool probe to begin and wondered it that was a calibration issue or not.
    Mar 2016
    Poland
    that depends on measuring macro. U can always add the XY position in machine CS for measuring. Probably nit in every version it is added in factory.
    Apr 2005
    Paradise, Ca, USA
    Quote Originally Posted by tez View Post
    More information is always helpful. What year machine? They do not all act the same. Which measuring routine are you trying to use? They do not all act the same. For example, on my '07, "Automatic Length Only" and "Automatic Length Rotating" both go to X/Y over the probe automatically, but "Manual Length Only" does NOT move X or Y.
    Jul 2008
    when you go threw the calibration steps then your machine will work just like the video. Do you have a classic control or the Next Gen control?
  7. #7
    Jul 2014
    Quote Originally Posted by Matt@RFR View Post
    X2. Also if you calibrate the probe the control knows where it is.
HAAS Tool Probe
HAAS Tool Probe
