VF5 TABLE PROBE CALIBRATION
Results 1 to 5 of 5
Thread: VF5 TABLE PROBE CALIBRATION
    Sep 2016
    Default VF5 TABLE PROBE CALIBRATION
    I am trying to do a table probe calibration. before i do probe calibration. I have everything setup and when i try to mdi the calibration it goes up and doesn't touch of on the probe. does anyone have any idea what the issue is??
    Jun 2016
    Default Re: VF5 TABLE PROBE CALIBRATION
    See this video for good overview on how to calibrate probe:
    Dennis
    Jun 2016
    Also, make sure you calibrate probe tip so it runs true otherwise your measurements with the probe will be off.
    Dennis
    Apr 2004
    O.C. Californa
    That video is on a next gen control. If you have an older Haas it won't work. Check your batteries on both tool presetter and spindle probe. Search youtube for haas automation probe troubleshooting.
    Feb 2010
    This manual should help you out better.
    Good luck!
    Attached Thumbnails Attached Thumbnails VF5 TABLE PROBE CALIBRATION-haas-mill-wips-vqcps-training-manual-pdf
