Go to current commands page and that will show you the position and a few lines of code. Or, go to position screens and select the screen you wish to watch.
Mike
Thanks for reading, We just got a 2004 VF6 and I got it all set up and ran test cuts last night, very happy with the circularity of the holes it made, but its kind of nerve wracking not being able to see the current position while the program is running, is there a parameter or setting I can change to make this visible? The only thing that shows at this point is lines of G code. I haven't been on a Haas in several years so I'm rusty on a lot of the control, been running Fadals. Thanks again
Mike
Two Haas VF-2's, Haas HA5C, Haas HRT-9, Hardinge CHNC 1, Bother HS-300 Wire EDM, BobCAD V23, BobCAD V28
Thanks, that's the screen I was looking for.
