Fault in program
Results 1 to 5 of 5
Thread: Fault in program
    Nov 2017
    United Kingdom
    Default Fault in program
    Hi have a haas vf4ss when I am machine a Complexed job with loads of little pockets it keeps leaving little marks where the tool start to ramp down before it get to where the pocket is if I put absolute stop Check on this will not happen but the cycle time will Increase loads does anyone else have this problem and know how to fix
    Registered Fletch_CNC's Avatar
    Jun 2015
    Default Re: Fault in program
    You mean the tool is gouging the top surface outside of the pocket? That could be happening because you are ramping down outside of the pocket boundary. I would think either raising your R-plane a little, or not ramping outside of the pocket should solve the problem.
    You say it doesn't happen if you turn on Exact Stop, so it is probably a problem with the rounding that occurs between moves. You could try putting G61 (exact stop) before the positioning moves, so that the corners aren't rounded. Then put G64 right after you get in position, so that your pocketing moves aren't done in exact stop, which will slow things down.
    ________________________________________________
    My blog: http://www.fletch1.com
    Nov 2017
    United Kingdom
    Quote Originally Posted by Fletch_CNC View Post
    That right if I put g61 in the job is fine but had 20min it the cycle time just wondering if there's something else I can do
    Nov 2017
    United Kingdom
    Quote Originally Posted by mat227 View Post
    This is a picture of what is happening
    Member extanker59's Avatar
    Mar 2008
    It's not clear in your answers but can you confirm that you have done as Fletch said and turned on G61 to position above each hole then turned it off each time? That wouldn't add to much time IMO but will be a PIA if there are a lot of holes. On the other hand, program once for many parts...
    Also, no picture showed up.
Fault in program
Fault in program
