Need Help! Haas EC-400 APC lift cam may be damaged.
Results 1 to 3 of 3
Thread: Haas EC-400 APC lift cam may be damaged.
    Member hutch07's Avatar
    Sep 2007
    Exclamation Haas EC-400 APC lift cam may be damaged.
    Looking for help finding haas 2005 parts for an EC-400. The lift on the APC will not go all the way up and I think it is the cam on the inside. It looks repairable from the manual but I am looking for parts.
    Any help would be appreciated.
    Haas EC-400 APC lift cam may be damaged.-ec-400-apc-jpg
    Oct 2017
    United Kingdom
    Default Re: Haas EC-400 APC lift cam may be damaged.
    Search | Haas Parts | Genuine OEM Haas Automation® Parts Factory-Direct
    Or just go on haas arts webside & type your machine serial number.
    You're not getting any alarms?
    Sep 2007
    The 3 balls had major contamination. Pounds of rust and dust in the cam tracks. While we had it open we replaced :
    (1) 51-0152 BEARING TAPERED ROLLER
    (3) 59-0616, BALL 1 7/8 APC
    (1) 20-2110A CAM , $895.00
    Parts ordered from Gerotech - one day delivery - THANKS!!!
    Problem solved mechanically. We are now trying to get the APC (W axis) to home correctly.
