The Haas post should automatically jump into the G154 offsets when you specify a value higher than 6. So if you call it offset "7" in Fusion, it should output a G154 P1, etc
Hey guys. I have too many products now that we make and need to start using offsets higher than the G54 through G59.
To use the offsets in Fusion 360, I add a number in the setup sheet that corresponds to an offset. G54 is 0 or 1, G55 is 2, G57 is 4, etc.
Are the next number G54 P1, G54 P2 etc?
If so, how do I implement them in Fusion?
Lee
What Ydna said, G154P1 G154 P2, etc. You can also use G110, G111, etc. Your post processor should be set up to handle it one of these ways.
Excellent.
Thanks, Guys.
Lee
Well that could explain it I've been scratching my head! With Fusion I plug in 54 for a offset but the new gen generator puts it as 154, so I take it I just enter 1 for 54. The other thing is it puts the feed rate at 650 and the TM1p dosen't run till it is lowered. I did change it in the post generator line 38 I belive, I'll have to check I might have the HSM turned off.
