Hey everyone!
I have a *used* Haas VF2SS for sale. Anyone know of someone who needs a machine like this?
One Owner Machine has only 4195 Cutting Hours. Equipped with 12000rpm, 24 tool High speed Side Mount tool changer, 1400 IPM, expanded Memory and many more features. On our Floor now, fully powered / tested & is in Great working condition
2014 Haas VF2SS
HAAS VF2SS VERTICAL MACHINING CENTER Equipped With:
12,000 RPM Direct Drive Spindle
1400 Inch Per Min. Rapid
Rigid Tapping
USB Drive
User Definable Macros, Spindle Orientation and Coordinate Rotational Scaling
Brushless servo drive motors on all axis
24 + 1 automatic high speed tool changer
Programmable coolant
Telescopic way covers
Chip auger
Flood Coolant system
Tooling Shelves
Tool Clamping Vise
Levelling Pads
Original Manuals
In Built 480V Transformer
HAAS VF2SS VERTICAL MACHINING CENTER Specifications:
Travels:
X-Axis: 30″
Y-Axis: 16″
Z-Axis: 20″
Rapid Traverse Rates: 1400 Inch Per Minute
Cutting Feed Rates: 833 Inch Per Minute
Spindle Nose to Table (Min.- Max.): 4″ – 24″
Table:
Length: 36″
Width: 14″
Number of Std T-Slots: 3
T-Slot Width: 5/8″
Max Weight on Table: 1500 lbs
Spindle:
Taper Size: CAT 40
Speed Range: 0 – 12,000 RPM
Spindle Power: 30 HP
Max Torque: 90ft-lb @ 2000RPM
Automatic Tool Changer:
Capacity: 24 + 1
Max Tool Weight: 12 lbs
Max Tool Dia: 5″
Max Tool Length: 11″
Tool-to-Tool (avg.): 1.6 seconds
Chip to Chip (avg.): 2.2 seconds
General:
Air Required: 100 psi, 4 scfm
Power: 220v / 66FLA / 3-Phase
Overall Dimensions: 89″ x 92″ x 104″ High
Weight: 9200 lbs
MachineStation
4590 Eucalyptus Ave Chino, CA 91710
909-919-9600
