So we have three VR machines. We have a programmer that has tried to use the G155, G164, G174, and G184 tap cycles. None of them work. G174 and G184 move to position and do nothing else. G155 turns the spindle the wrong direction and goes to deep. G164 does the same as G155. Has anyone ever used this option on a VR machine?
Contact Haas Automation in Oxnard California. Ask for apps dept or choose the phone option of software related questions. Tell the guy your issue and they will help you solve your problem,
Sounds like a control/software issue. You probably should get a tech in there. unfortunately if we tell you to try something it won't be covered under warranty that your HFO could provide you. Definitely sounds like a control issue
