I have the a new maincon board and a new mocon board for sell. Company is going out of business need to sell asap if anyone is interested.
- VF-2 crash----replaced mocon board but not sure it's fixed.
- Need Help!- Low Voltage Alarm, Changed the Mocon Board
- Need help about MOCON Board of MIKRON Turning Center
- Need Help!- Project! Haas Vector Drive replacement, MOCON board / Brushless Servo Amp interface
They're both backwards compatible with older controls. If your old processor goes this is the processor that you upgrade to. So it'll go in any lathe or Mill up to before the NGC.
Although it has to be a brushless machine
Are you sure? I don't think you can mix coldfire with non coldfire stuff.
I'm 100% sure, once you change over to this processor if you have the 68k processor you'll have to get the rest of the control upgrade. Although as far as it being compatible with your other boards I'm 100% sure it's compatible.
Also if you have a 2010-2015 HAAS then these boards will swap out without a control upgrade.
