Haas Super Mini Mill 2 ATC problem
Results 1 to 7 of 7
Thread: Haas Super Mini Mill 2 ATC problem
    Mar 2017
    Default Haas Super Mini Mill 2 ATC problem
    Hi, Im new to the forum so hopefully this is the right place to post this.
    I have a 2009 Haas Super Mini Mill 2 with the side mount tool changer.
    Im having an intermittent problem during tool changed where the drawbar doesn't seem to be activating at all. The ATC arm pulls the tool holder out with a loud pop, during the switch to a new tool there is no air sound coming from the spindle like normal. Then when the arm goes to put the next tool in the spindle it jams the throws an alarm. I then have the go through the recovery and manually move the arm back. The second tool holder is jamming because the the draw bar is still closed so the pull stud is hitting it instead of going into it.
    When I manually put tools in the spindle the draw bar and air blast work perfectly every time. The problem is during MDI tool changed and while a program is running. Its happening more frequently and it feels like Im going to do damage if it persists.
    Has any one else had a similar problem? If so any insight on how to fix it?
    Mar 2014
    Default Re: Haas Super Mini Mill 2 ATC problem
    Vector,
    you could have an incorrect parameter value, incorrect setting value, the solenoids not operating correctly,I/O board could be bad or relays k9-k12 on the I/O board could be acting up. Hope this helps you
    Member mactec54's Avatar
    Jan 2005
    Add another thing to what HFO Tech has said the quick exhaust valve will be about shot by now and causes this same problem
    Mactec54
    Mar 2014
    Mactec54,
    Good call, but from what he is stating the precharge and Trp solenoids aren't even turning on.
    Jan 2005
    Quote Originally Posted by HFO Tech View Post
    Mactec54,
    The quick exhaust valve will cause this too, the rubber valve gets up in the inlet hole of where the precharge enters, and blocks it off, makes the solenoid valve appear to not be working
    Mactec54
    Mar 2014
    Although he should still hear the valve exhausting through its own muffler.
  7. #7
    Jan 2005
    Correct, and what you said if it is not even turning on then may be the top proximity switch, needs a look at
    Mactec54
