I have a problem with a machine HAAS VF-0 year 1999, which does not reference the Y axis. The machine was working normally. I do not know if I should change parameters? The servo amplifier does not show alarm. What could be happening? Does anyone have the original parameters of the machine?
Before changing anything I might slide the way covers out of the way and check the limit switch. They can get jammed with chips or just gummy.
I had the VF-0 as my first machine
Gary
Hi Gary. If you check the switches, they work fine. With more patience, check the parameters of the Y axis, and found the maximum speed in 0, I do not understand how to change "alone". I corrected that parameter and the machine is working correctly.
