I have the 20HP perfect phase for my '15 VF-2 and it runs fine although I'm not hogging with it. Not sure what your work load is going to be on it. I can't imagine using the 10HP unit. When the spindle ramps to max after a tool change it definitely pulls some serious amperage for a few seconds. I once caught the LCD showing 71A on the wild leg, obviously a peak because I'm only feeding it with 100A panel. Without a heavy spindle load I commonly see 16-20A on the LCD (only shows amps for the wild leg, highly recommended tho because at least you can see something). I don't use the coolant pump or 4/5 axis so pretty minimal config with a 15K spindle. Hope this helps.
