Hey guys,
Thanks for the responses. We've spent the afternoon looking at the switches, and fortunately I was just able to recreate the issue. Unfortunately, I believe that rules out the switches which are an easy/cheap fix.
We created a tool change program that does nothing but change tools over and over again. On the diagnostic page, I was able to confirm that the switches appear to be working properly and don't seem to be sticking at all. The release to 0 as soon at the shuttle moves off of them.
Here is why I believe I've ruled out the switches:
In the middle of this tool change program, the problem occurred in the following sequence
Hey guys,
- Call for tool change
- Spindle moves up into position
- Shuttle moves in slightly, <.5". Just enough for the Out-Switch to show 0.
- The In-Switch still showed 0 - as it had since the shuttle retracted after the previous tool change.
- Spindle releases tool, dropping it on the part below
- Carousel rotates to new tool. (shuttle still in out position)
- Shuttle moves back out slightly until Out-Switch shows 1.
- Machine continues operation, without tool in spindle.
So, in my first observation I missed point #3. In this observation, I was clearly able to see that the In-Switch was NOT telling the machine that the shuttle had moved into position before it had released the tool.
Anything else I can look at?
Thanks!
Tom
