I found it. It plugs into the board that is off to the right of the fan shroud. A little plug labeled something cryptic like "fan".
I have a 2000 HAAS VF2 and I am replacing the backup battery. I was removing the metal shroud protecting the circuit boards and I accidentally unplugged the wire to the fan that is bolted to that shroud. I have not been able to figure out where that wire was plugged. Does anyone out there have any suggestions?
Thanks in advance!
Aaron
Knew you would find it!
Two Haas VF-2's, Haas HA5C, Haas HRT-9, Hardinge CHNC 1, Bother HS-300 Wire EDM, BobCAD V23, BobCAD V28
