Haas Renishaw Probe - Page 2
Page 2 of 2 FirstFirst 12
Results 13 to 18 of 18
Thread: Haas Renishaw Probe
  1. #13
    Aug 2005
    I just had a demp of Verisurf in my shop yesterday. It is VERY easy to use this software and a Faro arm to do just what you are asking. I also do a bit of reverse engineering. This software was designed to do just that. It is model based in that for inspection, it compares probe hits, calculates a vector, and gives deviation. It also will generate very dense point clouds because it is a scanning probe.
    The cost of a new arm and the software is about $50k. The software is about $15k
    I'll be placing an order in about a month.
  2. #14
    May 2004
    United Kingdom
    Quote Originally Posted by Verissimo View Post
    Renishaw Productivity + does not digitizes, you have to import a model select measur points and from them update work or tool ofsets , and some logic to identify a piece on the machine.
    The main use of Productivity+ is to do in process control - and for this it is an excellent tool (you do not need to have a model).
    It does also do digitising in a round about way. You can specify a region and how many points you wish to measure, and then select output points to dprnt the raw point data.
    If you wish to know more, please send me a pm.
  3. #15
    Apr 2008
    I inherited a Haas TP-1 small tool room lathe that has been sitting in my shop for over a year. I recently started a project for this machine that add a small drilled hole relative to a blind bore on a square part. This machine does a good job but the hole isn’t always in the correct position, so locating on the outside square sometimes produces an out of location hole (scrap). I want to add a probe routine to the Haas to correct the out of location condition. I use a MACRO statement and work coordinate shift to enter the hole location in G54 & G55. I want to hard program this rather than using one of the operator interactive programs.
    Can anyone out there help with this simple program? Renishaw and Haas haven’t been overly helpful. They have steered me to the manuals, but I don’t currently have these.
    Any help would be appreciated.
  4. #16
    Registered extanker59's Avatar
    Mar 2008
    Here is what I use:
    N25 (PROBE)
    T25 M6
    G0 G90 G58 X0 Y0 M5
    G43 H25 Z3.
    G65 P9832 (TURNS PROBE ON)
    G65 P9810 Z-.25 F50. (PROTECTED MOVE INTO BORE)
    G65 P9023 A1. D.75 S58. (PROBE BORE)
    G0 Z3.
    G53 Y0 Z0
    M1
    I have a list of most of the VQC macros which I got just by calling up each one and writting them down. I added the tool calls and moves, of course.
    I am assuming you have VQC?
  5. #17
    Jun 2009
    Two other products that might help you:
    PC-DMIS NC: Can drive your machine to measure easily and set work offsets. http://pcdmis.com/pc-dmis-nc
    Romer Arm: www.Romer.com
  6. #18
    Apr 2004
    O.C. Californa
    Default Inspection Plus
    If you purchased the probe from HAAS already loaded are the macros for some routines call Renishaw ask for the manual H-2000-6222-00-B or whatever is newer if the have one. They should email a pdf.
    Bob Aikins
    Applications
    Haas Factory Outlet Anaheim CA
Haas Renishaw Probe
Haas Renishaw Probe
