Need Help! Need help for make threading cnc programe
Results 1 to 7 of 7
Thread: Need help for make threading cnc programe
    Jan 2009
    Sri Lanka
    Unhappy Need help for make threading cnc programe
    How can i write this programe to run Hass CNC lathe M/c
    Part outer Diameter 42.5mm
    Length: 100mm
    Pitch 80mm
    No of starts: 45
    Left and Right hand thread
    Depth: 1mmNeed help for make threading cnc programe-multi-jpg
    Member KH0UJ's Avatar
    Jul 2016
    Philippines
    Default Re: Need help for make threading cnc programe
    Actually you dont need to write a CAM program for that, just buy a knurling tool for lathe then voila it can finish the work in seconds, not several minutes...
    Attached Thumbnails Attached Thumbnails Need help for make threading cnc programe-jfbl-1-8mm-pitch-dual-wheel-slant   Need help for make threading cnc programe-55-370-732-jpg
    Jan 2009
    Sri Lanka
    if it is possible to depth 1mm by nurling tool...
    Nov 2006
    It's technically possible to cut a knurl with single-point passes, but there are many limitations to it. Like he said above, it's VERY slow since the cutting tool will run into feedrate limits. You also need to have clearance on either side of the knurled area (like 5mm, depending on the RPM)
    In the past I tried to make a knurl using a thread tool (we did not have enough room in the turret for any other tools) but the program needed to be tweaked over and over. I was never successful with it (you could see the knurl marks change shape because of the machine accelerating and decelerating)
    So I would agree, a knurl tool is easier by far! You'll need to purchase the correct knurling wheel to create a "coarse" pattern.
    Jul 2016
    Philippines
    I can give him a programmed g-code for the one he actually wants but yes it's painfully slow, im guessing 15 minutes per work, unlike a knurling tool 10 seconds good to go hehe
    Sent from my SM-J120H using Tapatalk
    Jan 2009
    Sri Lanka
    Quote Originally Posted by KH0UJ View Post
    Please brother give me programe, just i like to test that programe.
    thanks
  7. #7
    Jan 2009
    Sri Lanka
    Quote Originally Posted by Ydna View Post
    thanks for your information. above mention details, how can i choose knurling tool? give me some details.
