Need Help! Engraving using Radial live tool programming issues!
Results 1 to 17 of 17
Thread: Engraving using Radial live tool programming issues!
    Default Engraving using Radial live tool programming issues!
    Guys,
    I've got an ST-30Y and I'm trying to engrave on a barrel that's chucked up between the chuck and tailstock. Just trying to put some text along the Z-axis (G19 plane) and it's driving me nuts!! I used to do this as a 2nd operation on the mill with a 4th axis, using G107 Cylindrical Mapping. The equivalent on the lathe seemed to be G112, but I've had zero luck with that. The G112 worked great for me when I had to cut a hex shape on a part in the G17 plane, so I know: A) My machine works B) I'm not a *complete* idiot. None of my CAM systems have enough axes to just plug and play this job, so that's off the table. Would someone please post some code that shows engraving on the OD of a bar using a radial live tool? I don't even care if it doesn't use the C axis (I tried that and failed, too). Thanks!
    Attached Thumbnails Attached Thumbnails Engraving using Radial live tool programming issues!-50bmgtext-jpg
    May 2013
    Default Re: Engraving using Radial live tool programming issues!
    This engraved ".50 BMG" in 0.250 tall letters around 1.0 diameter stock .005 deep starting at Z-4. working toward Z+ on our ST10-Y.
    O50000
    (.50 BMG )
    T1010
    M154
    G97 P3000 M133
    G98 M8
    G0 X1.2 Y0 Z-3.9405
    X1.1 C11.596
    G1 X0.99 F5.
    Z-3.9524 C12.96 F10.
    Z-3.9405 C14.324
    Z-3.9286 C12.96
    Z-3.9405 C11.596
    G0 X1.2
    Z-3.7024 C-14.324
    X1.1
    G1 X0.99 F5.
    Z-3.8214 F10.
    Z-3.8333 C-2.046
    Z-3.8214 C-3.411
    Z-3.7857 C-4.775
    Z-3.75
    Z-3.7143 C-3.411
    Z-3.6905 C-0.682
    Z-3.6786 C3.411
    C6.139
    Z-3.6905 C10.231
    Z-3.7143 C12.96
    Z-3.75 C14.324
    Z-3.7857
    Z-3.8214 C12.96
    Z-3.8333 C11.596
    Z-3.8432 C8.867
    G0 X1.2
    Z-3.5337 C-14.324
    X1.1
    G1 X0.99 F5.
    Z-3.5694 C-12.96 F10.
    Z-3.5932 C-8.867
    Z-3.6051 C-2.046
    C2.046
    Z-3.5932 C8.867
    Z-3.5694 C12.96
    Z-3.5337 C14.324
    Z-3.5099
    Z-3.4741 C12.96
    Z-3.4503 C8.867
    Z-3.4384 C2.046
    C-2.046
    Z-3.4503 C-8.867
    Z-3.4741 C-12.96
    Z-3.5099 C-14.324
    Z-3.5337
    G0 X1.2
    Z-3.0575 C-0.682
    X1.1
    G1 X0.99 F5.
    Z-3.0218 C0.682 F10.
    Z-3.0099 C2.046
    Z-3. C4.775
    C8.867
    Z-3.0099 C11.596
    Z-3.0218 C12.96
    Z-3.0575 C14.324
    Z-3.1646
    C-14.324
    Z-3.0575
    Z-3.0218 C-12.96
    Z-3.0099 C-11.596
    Z-3. C-8.867
    C-6.139
    Z-3.0099 C-3.411
    Z-3.0218 C-2.046
    Z-3.0575 C-0.682
    Z-3.1646
    G0 X1.2
    Z-2.9146 C14.324
    X1.1
    G1 X0.99 F5.
    C-14.324 F10.
    Z-2.8194 C14.324
    Z-2.7241 C-14.324
    C14.324
    G0 X1.2
    Z-2.4622 C-7.503
    X1.1
    G1 X0.99 F5.
    Z-2.4721 C-10.231 F10.
    Z-2.4959 C-12.96
    Z-2.5197 C-14.09
    Z-2.5673
    Z-2.5912 C-12.96
    Z-2.615 C-10.231
    Z-2.6248 C-7.503
    Z-2.6367 C-3.411
    C3.411
    Z-2.6248 C7.503
    Z-2.615 C10.231
    Z-2.5912 C12.96
    Z-2.5673 C14.09
    Z-2.5197
    Z-2.4959 C12.96
    Z-2.4721 C10.231
    Z-2.4622 C7.503
    C3.411
    Z-2.5218
    G0 X1.2
    M9
    G28 M135
    M155
    M30
    Hey, thanks! That actually runs on my machine. It's kind of clunky, though...seems like the C axis keeps putting on the brake during Z moves. That makes sense when you're doing serious cutting but a .010" tip engraving bit doesn't really require it. Wonder if there's a setting to turn that off?
    May 2013
    It probably has more to do with the resolution of the text. You could add an M15 to make sure the main spindle brake stays off.
    Aug 2015
    Not to hijack the thread but if you find a way to make G112 work in G18 or G19 I would be grateful to hear it. The code has to be output with Z changed to X, X changed to Z, and Y stays because its converted to C through G112. I haven't found a way to do it in software yet. Regular 3 axis mill code works for G17 & G112.
    Aug 2015
    I got it using G112 and G19.
    I'm using Mastercam with a 3X haas mill post. Its tricky but I can walk you through it.
    The code below will engrave a 1" tall letter D on a 5" cylinder. It does work. I ran it on our ST30 SSY.
    O10205
    G20
    ( 1/4 INCH ENGRAVING TOOL 60 DEGREE X .030 TIP)
    G00 T1313
    G19
    M154
    G112
    G00 G54 X3. Y0. Z-2.
    X2.6
    G97 P950 M133
    G98 G01 X2.5 F25.
    Y0.1249 X2.4969 F5.
    Y0.2496 X2.4875
    Y0.3736 X2.4719
    Y0.4967 X2.4502
    Z-1.7211
    Z-1.7104 Y0.4955 X2.4504
    Z-1.7029 Y0.4945 X2.4506
    Z-1.6953 Y0.4934 X2.4508
    Z-1.6878 Y0.4921 X2.4511
    Z-1.6803 Y0.4906 X2.4514
    Z-1.6728 Y0.489 X2.4517
    Z-1.6653 Y0.4872 X2.4521
    Z-1.6579 Y0.4853 X2.4524
    Z-1.6506 Y0.4833 X2.4528
    Z-1.6433 Y0.481 X2.4533
    Z-1.636 Y0.4787 X2.4537
    Z-1.6288 Y0.4761 X2.4542
    Z-1.6216 Y0.4735 X2.4548
    Z-1.6145 Y0.4707 X2.4553
    Z-1.6075 Y0.4677 X2.4559
    Z-1.6005 Y0.4646 X2.4564
    Z-1.5936 Y0.4614 X2.4571
    Z-1.5867 Y0.458 X2.4577
    Z-1.58 Y0.4544 X2.4583
    Z-1.5733 Y0.4508 X2.459
    Z-1.5666 Y0.447 X2.4597
    Z-1.5601 Y0.443 X2.4604
    Z-1.5536 Y0.4389 X2.4612
    Z-1.5473 Y0.4347 X2.4619
    Z-1.541 Y0.4304 X2.4627
    Z-1.5348 Y0.4259 X2.4635
    Z-1.5287 Y0.4213 X2.4642
    Z-1.5227 Y0.4166 X2.465
    Z-1.5169 Y0.4117 X2.4659
    Z-1.5111 Y0.4068 X2.4667
    Z-1.5054 Y0.4017 X2.4675
    Z-1.4998 Y0.3964 X2.4684
    Z-1.4944 Y0.3911 X2.4692
    Z-1.489 Y0.3857 X2.4701
    Z-1.4838 Y0.3801 X2.4709
    Z-1.4787 Y0.3745 X2.4718
    Z-1.4737 Y0.3687 X2.4727
    Z-1.4688 Y0.3628 X2.4735
    Z-1.4641 Y0.3568 X2.4744
    Z-1.4594 Y0.3508 X2.4753
    Z-1.4549 Y0.3446 X2.4761
    Z-1.4506 Y0.3383 X2.477
    Z-1.4464 Y0.332 X2.4779
    Z-1.4423 Y0.3255 X2.4787
    Z-1.4383 Y0.319 X2.4796
    Z-1.4345 Y0.3124 X2.4804
    Z-1.4308 Y0.3056 X2.4812
    Z-1.4273 Y0.2989 X2.4821
    Z-1.4239 Y0.292 X2.4829
    Z-1.4206 Y0.2851 X2.4837
    Z-1.4179 Y0.277 X2.4846
    Z-1.4108 Y0.2543 X2.487
    Z-1.4043 Y0.2315 X2.4893
    Z-1.3984 Y0.2085 X2.4913
    Z-1.3931 Y0.1853 X2.4931
    Z-1.3884 Y0.1619 X2.4948
    Z-1.3844 Y0.1384 X2.4962
    Z-1.381 Y0.1149 X2.4974
    Z-1.3783 Y0.0912 X2.4983
    Z-1.3761 Y0.0674 X2.4991
    Z-1.3746 Y0.0436 X2.4996
    Z-1.3738 Y0.0197 X2.4999
    Z-1.3736 Y-0.0042 X2.5
    Z-1.374 Y-0.028 X2.4998
    Z-1.3751 Y-0.0519 X2.4995
    Z-1.3768 Y-0.0757 X2.4989
    Z-1.3791 Y-0.0995 X2.498
    Z-1.3821 Y-0.1231 X2.497
    Z-1.3857 Y-0.1467 X2.4957
    Z-1.39 Y-0.1702 X2.4942
    Z-1.3949 Y-0.1935 X2.4925
    Z-1.4004 Y-0.2167 X2.4906
    Z-1.4065 Y-0.2397 X2.4885
    Z-1.4133 Y-0.2625 X2.4862
    Z-1.4206 Y-0.2851 X2.4837
    Z-1.4252 Y-0.2947 X2.4826
    Z-1.4286 Y-0.3015 X2.4818
    Z-1.4322 Y-0.3082 X2.4809
    Z-1.4359 Y-0.3148 X2.4801
    Z-1.4398 Y-0.3214 X2.4793
    Z-1.4437 Y-0.3279 X2.4784
    Z-1.4479 Y-0.3343 X2.4776
    Z-1.4521 Y-0.3406 X2.4767
    Z-1.4565 Y-0.3468 X2.4758
    Z-1.461 Y-0.3529 X2.475
    Z-1.4657 Y-0.3589 X2.4741
    Z-1.4705 Y-0.3649 X2.4732
    Z-1.4754 Y-0.3707 X2.4724
    Z-1.4804 Y-0.3764 X2.4715
    Z-1.4855 Y-0.382 X2.4706
    Z-1.4908 Y-0.3875 X2.4698
    Z-1.4962 Y-0.3929 X2.4689
    Z-1.5017 Y-0.3982 X2.4681
    Z-1.5073 Y-0.4034 X2.4672
    Z-1.513 Y-0.4084 X2.4664
    Z-1.5188 Y-0.4133 X2.4656
    Z-1.5247 Y-0.4181 X2.4648
    Z-1.5307 Y-0.4228 X2.464
    Z-1.5368 Y-0.4274 X2.4632
    Z-1.543 Y-0.4318 X2.4624
    Z-1.5494 Y-0.4361 X2.4617
    Z-1.5558 Y-0.4403 X2.4609
    Z-1.5622 Y-0.4443 X2.4602
    Z-1.5688 Y-0.4482 X2.4595
    Z-1.5755 Y-0.452 X2.4588
    Z-1.5822 Y-0.4556 X2.4581
    Z-1.589 Y-0.4591 X2.4575
    Z-1.5959 Y-0.4625 X2.4569
    Z-1.6028 Y-0.4657 X2.4562
    Z-1.6098 Y-0.4687 X2.4557
    Z-1.6169 Y-0.4716 X2.4551
    Z-1.6241 Y-0.4744 X2.4546
    Z-1.6313 Y-0.477 X2.4541
    Z-1.6385 Y-0.4795 X2.4536
    Z-1.6458 Y-0.4818 X2.4531
    Z-1.6532 Y-0.484 X2.4527
    Z-1.6606 Y-0.486 X2.4523
    Z-1.668 Y-0.4879 X2.4519
    Z-1.6755 Y-0.4896 X2.4516
    Z-1.683 Y-0.4912 X2.4513
    Z-1.6906 Y-0.4926 X2.451
    Z-1.6982 Y-0.4938 X2.4507
    Z-1.7058 Y-0.4949 X2.4505
    Z-1.7134 Y-0.4959 X2.4503
    Z-1.7211 Y-0.4967 X2.4502
    Z-2.
    Y-0.3736 X2.4719
    Y-0.2496 X2.4875
    Y-0.1249 X2.4969
    Y0. X2.5
    X2.6 F50.
    G00 X3.
    M135
    M155
    G00 X8.
    G00 Z4.
    T1300
    M30
    Attached Thumbnails Attached Thumbnails Engraving using Radial live tool programming issues!-img_3197-jpg
  7. #7
    It obviously works, but are you actually moving the C axis with that program? Looks like it's just moving the three linear axes simultaneously with no rotation.
    Quote Originally Posted by ERUS View Post
  8. #8
    Aug 2015
    Yes. If you run it on the machine you can see the C axis turning as its engraving. X stays at 5" diameter through the whole run. I didn't think it would by just looking at the code, but it did.
    Using G112, when there is a Y move in the program it converts it to a C move. When the machine is at X0. the wedge will only allow the Y to move +\-2.0". By using G112 Cartesian to polar transformation it converts the X&Y moves into X&C moves this allows you to machine around 5" diameter part even though the travel is only +\- 2.0" in Y. The machine itself is doing the math when you use G112. But it is less accurate than if you just used the X&Y as you would on a regular cnc. With G112 the tolerance is about +\- 0.001" at a 5" diameter. It get worse as the diameter grows from 5" because the resolution for the C-axis just isn't there.
    I modified a 3X mill post to swap the X and Z axes. I don't know what software you are using but the geometry for the D wasn't flat it was curved on a 5" cylinder, and I used a 3D contour toolpath to follow the curve. I could not get it to work if it output the code as G2 or G3 arc with I,J,or K. It has to be line segments.
    If you tell me what text you want, character size, and the diameter of the cylinder its going on I can post some code?
  9. #9
    Ok, I guess what throws me is that I'm not used to seeing simultaneous 3-axis moves for engraving. Normally it's Z down to the depth and then X-Y moves. Of course in G19 we're in the Z-Y plane and X is acting like Z (for those of use who are mill-minded). But it's still a bit odd that your X isn't just moving to a value and staying there while the character is being cut. I'd like to see the code for two characters and see if the X value rapids up between them. I finally got some code to work for my barrel engraving but I'm just using X and Y, not C. I guess I'll try doing a G112 but the main thing that throws me is that I can't find where to stick the diameter for the axis conversion. On the mill it's G107 and there is a Q value where up specify the diameter. Can't find an equivalent for the G112 yet... Sure, I'd like to see some code: text is: 50 BMG diameter is 1.150". Character height is .1 Thanks!
  10. #10
    Aug 2015
    O10205
    G20
    G00 T1313
    G19
    M154
    G112
    G00 G55 Z-.9201 Y.1237 X1.
    X0.75
    X0.6
    G97 P1750 M133
    G98 G1 X.4845 F25.
    G19 Y.0888 X.4921 F7.
    Y.0535 X.4972
    Y.0179 X.4997
    Y-.0179
    Y-.0535 X.4972
    Y-.0888 X.4921
    Y-.1237 X.4845
    X.6 F50.
    G0 X.75
    G17
    Z-1.
    X.6
    G1 X.4845 F25.
    Z-.9201 F7.
    Z-.8402
    X.6 F50.
    G0 X.75
    Z-.7902
    X.6
    G1 X.4845 F25.
    G19 Y-.0932 X.4913 F7.
    Y-.0623 X.4961
    Y-.0312 X.4991
    Y0. X.5
    Y.0312 X.499
    Y.0623 X.4961
    Y.0932 X.4912
    Y.1237 X.4845
    Z-.6436
    X.6 F50.
    G0 X.75
    G17
    Z-.7902 Y0.
    X.6
    G1 X.5 F25.
    Z-.6757 F7.
    X.6 F50.
    G0 X.75
    Z-.7902 Y-.1237
    X.6
    G1 X.4845 F25.
    Z-.6436 F7.
    X.6 F50.
    G0 X.75
    Z-.4429 Y-.0891
    X.6
    G1 X.492 F25.
    Z-.4448 Y-.0919 X.4915 F7.
    Z-.4467 Y-.0947 X.491
    Z-.4488 Y-.0973 X.4904
    Z-.4509 Y-.0999 X.4899
    Z-.4533 Y-.1023 X.4894
    Z-.4557 Y-.1047 X.4889
    Z-.4582 Y-.1069 X.4884
    Z-.4609 Y-.109 X.488
    Z-.4636 Y-.111 X.4875
    Z-.4664 Y-.1128 X.4871
    Z-.4693 Y-.1145 X.4867
    Z-.4723 Y-.1161 X.4863
    Z-.4754 Y-.1175 X.486
    Z-.4785 Y-.1188 X.4857
    Z-.4817 Y-.1199 X.4854
    Z-.4849 Y-.1209 X.4852
    Z-.4882 Y-.1218 X.4849
    Z-.4915 Y-.1225 X.4848
    Z-.4948 Y-.123 X.4846
    Z-.4982 Y-.1234 X.4845
    Z-.5015 Y-.1236
    Z-.5041 Y-.1237
    Z-.5245 Y-.1239 X.4844
    Z-.5277
    Z-.531 Y-.1237 X.4845
    Z-.5343 Y-.1233
    Z-.5375 Y-.1228 X.4847
    Z-.5407 Y-.1222 X.4848
    Z-.5438 Y-.1214 X.4851
    Z-.5469 Y-.1204 X.4853
    Z-.55 Y-.1193 X.4856
    Z-.553 Y-.118 X.4859
    Z-.5559 Y-.1166 X.4862
    Z-.5587 Y-.1151 X.4866
    Z-.5615 Y-.1134 X.487
    Z-.5642 Y-.1116 X.4874
    Z-.5667 Y-.1096 X.4878
    Z-.5692 Y-.1076 X.4883
    Z-.5716 Y-.1054 X.4888
    Z-.5738 Y-.1031 X.4893
    Z-.5759 Y-.1007 X.4897
    Z-.5779 Y-.0982 X.4903
    Z-.5798 Y-.0956 X.4908
    Z-.5816 Y-.093 X.4913
    Z-.5832 Y-.0902 X.4918
    Z-.5846 Y-.0874 X.4923
    Z-.5859 Y-.0845 X.4928
    Z-.5871 Y-.0815 X.4933
    Z-.5881 Y-.0785 X.4938
    Z-.589 Y-.0754 X.4943
    Z-.5897 Y-.0723 X.4947
    Z-.5903 Y-.0692 X.4952
    Z-.5907 Y-.066 X.4956
    Z-.591 Y-.0628 X.496
    G19 Y-.0623 X.4961
    Z-.5906 Y-.0594 X.4965
    Z-.5901 Y-.0565 X.4968
    Z-.5895 Y-.0537 X.4971
    Z-.5886 Y-.0509 X.4974
    Z-.5877 Y-.0481 X.4977
    Z-.5865 Y-.0454 X.4979
    Z-.5853 Y-.0428 X.4982
    Z-.5839 Y-.0402 X.4984
    Z-.5823 Y-.0377 X.4986
    Z-.5806 Y-.0353 X.4987
    Z-.5788 Y-.033 X.4989
    Z-.5769 Y-.0308 X.499
    Z-.5749 Y-.0288 X.4992
    Z-.5727 Y-.0268 X.4993
    Z-.5705 Y-.0249 X.4994
    Z-.5681 Y-.0232 X.4995
    Z-.5657 Y-.0216
    Z-.5649 Y-.0211 X.4996
    Z-.5102 Y.0023 X.5
    Z-.4665 Y.0211 X.4996
    Z-.4657 Y.0216 X.4995
    Z-.4632 Y.0232
    Z-.4609 Y.0249 X.4994
    Z-.4586 Y.0268 X.4993
    Z-.4565 Y.0288 X.4992
    Z-.4544 Y.0308 X.499
    Z-.4525 Y.033 X.4989
    Z-.4507 Y.0353 X.4987
    Z-.449 Y.0377 X.4986
    Z-.4475 Y.0402 X.4984
    Z-.4461 Y.0428 X.4982
    Z-.4448 Y.0454 X.4979
    Z-.4437 Y.0481 X.4977
    Z-.4427 Y.0509 X.4974
    Z-.4419 Y.0537 X.4971
    Z-.4412 Y.0565 X.4968
    Z-.4407 Y.0594 X.4965
    Z-.4404 Y.0623 X.4961
    Y.0627
    Z-.4406 Y.0659 X.4956
    Z-.441 Y.069 X.4952
    Z-.4416 Y.0722 X.4948
    Z-.4423 Y.0753 X.4943
    Z-.4432 Y.0783 X.4938
    Z-.4442 Y.0814 X.4933
    Z-.4453 Y.0843 X.4928
    Z-.4466 Y.0872 X.4923
    Z-.4481 Y.0901 X.4918
    Z-.4497 Y.0928 X.4913
    Z-.4514 Y.0955 X.4908
    Z-.4533 Y.0981 X.4903
    Z-.4553 Y.1006 X.4898
    Z-.4574 Y.103 X.4893
    Z-.4597 Y.1053 X.4888
    Z-.462 Y.1075 X.4883
    Z-.4645 Y.1095 X.4879
    Z-.467 Y.1115 X.4874
    Z-.4697 Y.1133 X.487
    Z-.4725 Y.115 X.4866
    Z-.4753 Y.1165 X.4862
    Z-.4782 Y.1179 X.4859
    Z-.4812 Y.1192 X.4856
    Z-.4843 Y.1203 X.4853
    Z-.4874 Y.1213 X.4851
    Z-.4905 Y.1221 X.4849
    Z-.4937 Y.1228 X.4847
    Z-.4969 Y.1233 X.4846
    Z-.5002 Y.1237 X.4845
    Z-.5034 Y.1239 X.4844
    Z-.5067
    Z-.5322 Y.1237 X.4845
    Z-.535 Y.1236
    Z-.5383 Y.1234
    Z-.5417 Y.123 X.4846
    Z-.545 Y.1225 X.4848
    Z-.5483 Y.1218 X.4849
    Z-.5516 Y.1209 X.4852
    Z-.5548 Y.1199 X.4854
    Z-.558 Y.1188 X.4857
    Z-.5611 Y.1175 X.486
    Z-.5642 Y.1161 X.4863
    Z-.5672 Y.1145 X.4867
    Z-.5701 Y.1128 X.4871
    Z-.5729 Y.111 X.4875
    Z-.5757 Y.109 X.488
    Z-.5783 Y.1069 X.4884
    Z-.5808 Y.1047 X.4889
    Z-.5833 Y.1023 X.4894
    Z-.5856 Y.0999 X.4899
    Z-.5878 Y.0973 X.4904
    Z-.5898 Y.0947 X.491
    Z-.5918 Y.0919 X.4915
    Z-.5936 Y.0891 X.492
    X.6 F50.
    G0 X.75
    G17
    Z-.3104 Y.1237
    X.6
    G1 X.4845 F25.
    Y.0535 X.4972
    Y.0179 X.4997
    Y-.0179
    Y-.0535 X.4972
    Y-.0888 X.4921
    Y-.1237 X.4845
    X.6 F50.
    G0 X.75
    G17
    Z-.3904
    X.6
    G1 X.4845 F25.
    Z-.3104 F7.
    Z-.2305
    X.6 F50.
    G0 X.75
    G113
    M135
    M155
    G00 X10.
    G00 Z8.
    T1300
    M30
    Attached Thumbnails Attached Thumbnails Engraving using Radial live tool programming issues!-testg112-jpg
  11. #11
    Wow, thanks for all the effort! Only 2 things still bother me: 1) I can't seem to find ANYWHERE what the equivalent for the mill's G017 Q value is on the lathe. Maybe it just knows based on the tool offset? 2) I don't know why your program jumps back and forth between G19 and G17. I'm going to go out in the shop and play a bit and see if I can crack this nut!
  12. #12
    May 2013
    Setting 102?
  13. #13
    May 2013
  14. #14
    Aug 2015
    Yeah, I saw the G17s.
    I ended up doing a more lengthy test and took out the G17s. It input them because I'm using a 3 axis mill post to output the code.
  15. #15
    Aug 2015
    Here is a better video. I took the G17s out this time.
  16. #16
    Aug 2015
    The problem with the ST series lathes with a Y-axis is the spindles arent meant to function as a full fledged c-axis. That is why people have problems trying to program it like its a actual rotary axis. There is no code on the St series for the C to understand inverse time feeds like is present in true 4 axis programming. Also the c-axis brake is partly controlled in the firmware of the machine and it can be difficult to overcome its function. They are good for indexing, and accurate axial and radial machining if the work envelope is within the Y-axis travel limits. Anything else your best bet is G112 if you can work around it.
  17. #17
    Wow, thanks a ton for all your work trying to explain this. I still have yet to make anything other than just X-Y axis programming work, but as I get time I hope I'll zero in on the ultimate fix. Any chance you can post the code for your G112 example below?
    Thanks!
