- Problem- spindle rotate during G83 canned cycle
Spindle is starting during G83 cycle with live tool and C-axis engaged. C-axis and spindle are try to work at the same time
Re: spindle rotate during G83 canned cycle
Radial or axial live tool?
G83 Peck drill should work as normal for a Axial tool
If its a radial or side tool then you have to use G243.
Did you engage the C-axis with M154?
Here is a working code for using a Axial tool with a G83 peck canned cycle.
O00000
G20
(TOOL - 7 OFFSET - 7)
( 1 INCH DRILL)
(C-AXIS FACE DRILL)
G00 T0707
G17
M154
M8
G00 G54 X0. Z.25
C0.
G97 P250 M133
G98 G83 Z-1. R.1 Q.075 F4.0
G80
M9
G00 Z.25
G00 X8.
G00 Z8.
M135
M155
T0700
M30
Here is for a G243 Radial peck cycle.
O00000
G20
(TOOL - 9 OFFSET - 9)
( 1 INCH DRILL)
(C-AXIS CROSS DRILL)
G00 T0909
G19
M154
G00 G54 X4. Z-.8
C-90.
G97 P250 M133
G98 G243 X1. R3. Q.075 F4.
G80
G00 X8.
G00 Z8.
M135
M155
T0900
M30
Problem was in Parameter 315 bit 1 NO SPIND CAN CYCLE
- You may not post replies
- You may not edit your posts
Forum Rules
