| GRZ Software- MeshCAM Discuss GRZ Software- MeshCAM software here. |
I am new for CNC and CAD... I chose DesignCAD 3D Ver. 14 --> MeshCAM -->TurboCNC. I created sample CAD and exported as DFX file. (Ver. 14). But as you see, MeshCAM retrieved only one polygon. Is there any way to make this set work? What's wrong? DesignCAD export funtionality or simply the DFX file is not compatible with MeshCAM ? Help me... |
| If you send me the file I'd be happy to look at it but in general DXF files are fine if you only output 3dFaces- meshes and 2d elements cannot be read by MeshCAM. Robert
| Try exploding before you save as .dxf. Your drawing contains meshes, which are really just a series of 3D faces. Usually exploding will work. It does in AutoCAD. THis is what you should end up with.
__________________ Gerry Mach3 2010 Screenset http://home.comcast.net/~cncwoodworker/2010.html (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) Last edited by ger21; 04-11-2005 at 07:31 AM. |
| Robert. Any chances of adding Mesh support for .dxf import? It would probably eliminate the user having to explode meshes all the time.
Do I have to use "AccuTrans 3D" to convert from DFX which is not compatible with MeshCAM to STL? |
| As my previous post said, try exploding before you export as .dxf. It should work.
| Are you creating the object with solids in DesignCAD?
#11
| That's probably why the exploding doesnt work. What other file types can you export and import? Can you export .3ds, maybe, and import it back in?
#12
| [QUOTE = ger21; 75080] Robert. Todas as possibilidades de adicionar suporte para Mesh. Importação DXF? Provavelmente, seria eliminar o usuário tenha que explodir malhas em todo o tempo. [/ QUOTE] a amigo voce pode me ajudar a achar um modelo de relogio de parede? qualquer modelo. grata celia Brasil |
| Dinosaur skeleton, and other models, DXF files. | ynneb | DIY-CNC Router Table Machines | 2880 | 05-25-2012 02:28 PM |
| Zeroing imported parts | an0n | Mastercam | 4 | 01-10-2007 01:13 PM |
| converting to dfx | qsacracer | G-Code Programing | 31 | 04-26-2005 03:43 PM |
| Mechanical Dektop 2004 dfx error | fantasy2 | Autodesk Software (Autocad, Inventor etc) | 5 | 02-05-2005 07:39 AM |
| imported rotary tables | vacpress | General Metal Working Machines | 8 | 04-06-2004 10:03 PM |
