Results 1 to 2 of 2
Thread: Bmp
    Apr 2003
    Bmp
    Thanks Robert
    Your program looks great. I have been destroying lumber like crazy.
    I know that I have to pick the right size bit for the right size carving. My problem is what is the ideal looking bmp to start with. Could someone send me a simple drawing to sample? At least I could step in the right direction.
    Apr 2003
    Southern California
    I wish I could give you a number, but there's no right answer. You've got several parameters that affect the output.
    1) Relief dimensions. When you load a bitmap you must set the size of the finished relief.
    2) The bitmap dimensions. Whatever bitmap you use has a height and width defined in pixels. The more pixels, the more accurite you can machine a part. There is some limit to this though, a 1000x1000 bitmap is no good if you're going to machine it to a size of 1"x1"
    3,4) Toolpath stepover and cutter diameter. The stepover defines the distance between the parallel cutter passes used to cut the relief. Finer is better, but there is a point of diminishing returns. I'd start between 1/3 and 1/10 the cutter diameter.
    The best thing to do is try a buch and see how the output changes.
    Let me know if this helps,
    Robert
  1. BMP to G-code
    By jlagran he in forum G-Code Programing
    Last Post: 04-25-2011, 12:22 AM
  2. Image insert to world block
    By Niall in forum Autodesk Software (Autocad, Inventor etc)
    Last Post: 09-22-2004, 07:59 AM
