Results 1 to 3 of 3
Thread: Which way to turn stock for 2-sided machining
    Mar 2011
    united states
    Talking Which way to turn stock for 2-sided machining
    I havent done any two sided machining but have 22 patterns to cut that are all 2-sided. I use Meshcam3 build 17 The parts are cut from a blank of MDF that is 17X24 inches and 1 inch thick. On my meshcam screen the X axis is left to right and the Y axis is up and down. I locate the stock by the center which is drilled through the stock. I would like to know if I need to turn the material as a rotation about the Y axis where the left side becomes the right side and the top is still the top, or rotate about the X axis where the top becomes the bottom and left side remains the left side.
    wizzardworks
    Mar 2011
    united states
    Talking which way to turn oer stock
    Concerning the above post, I ran the files for the top side and then the bottom side in a simulator. The material was rotated around the X axis with the top becoming the bottom.
    wizzardworks
    Aug 2004
    Yes, that is the correct rotation.
    Paul
  1. 2-sided Machining - Centering the Part and Zeroing
    By ViperTX in forum GRZ Software- MeshCAM
    Last Post: 12-22-2011, 01:10 PM
  2. MeshCAM 4 Build, 2 sided machining
    Last Post: 10-09-2010, 04:37 PM
  3. 2 Sided Machining and outline of part
    Last Post: 06-12-2010, 12:50 AM
  4. Newbie- Multi-sided machining with VM5 Pro
    By rzmac in forum Visual Mill
    Last Post: 03-12-2010, 12:03 AM
  5. Unable to place support tags on 2-sided machining
    By LongRat in forum GRZ Software- MeshCAM
    Last Post: 07-22-2008, 03:01 PM
