Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > GRZ Software- MeshCAM
GRZ Software- MeshCAM Discuss GRZ Software- MeshCAM software here.
Old 05-09-2005, 06:39 PM
Sanghera is on a distinguished road
Circular Cut
I was just wondering if Meshcam can do a circular cut intead of parallel passes. I want it to follow the contour of the part, otherwise a jagged edge results.
Thanks.
Old 05-09-2005, 07:03 PM
ger21's Avatar
Use waterline, but to get it really smooth, you have to turn up oversampling pretty high.
Old 05-10-2005, 06:05 PM
What does oversampling do?
Thanks.
Old 05-11-2005, 06:40 AM
ger21's Avatar
It will make your toolpaths come out much smoother.
Old 12-22-2005, 10:06 PM
So no way to actually contour and follow a path eh? Any chance of it being in the next version?
Thanks.
Old 12-22-2005, 10:19 PM
If you are cutting a true circle or part of a circle why not direct program circular interpolation?
Old 12-22-2005, 10:21 PM
the_paco is on a distinguished road
"So no way to actually contour and follow a path eh? Any chance of it being in the next version?"
Why not?!
May I suggest to join the MeshCAM support group for suggestions to the editor...
My business Web site - USINUM - www.cooptel.qc.ca/~usinum
My BLOG at Blogger - http://pacosarea.blogspot.com/
Old 12-22-2005, 10:41 PM
ger21's Avatar
Thanks.
Sounds like you need a 2.5D CAM program, like SheetCAM.
Old 12-22-2005, 10:51 PM
Well, Sheetcam would work fine, but if you have seen contour on a program like Mastercam, you don't have to convert the 3d model to an outline to do that. You can just run your parallel passes, then finish it off with a contour that follows the edges to clean it up.
Thanks.
Old 04-14-2006, 01:06 PM
How does oversamplind make your toolpath smoother?
Thanks.
  #11   Ban this user!
Old 11-06-2006, 11:27 AM
bowber is on a distinguished road
I was going to post a question about profiling and saw this thread so has anything been done about profiling, I've been playing with Meshcam and really like it but it would be much better if the profiling was done with interpolated moves, circles etc, it just seems to go from point to point at teh moment.
I've been trying out the version 2 beta as well as version 1
steve
  #12   Ban this user!
Old 11-06-2006, 11:30 AM
robgrz is on a distinguished road
You can use the waterline option and then finish with a pencil toolpath to cleanup at the end.
-Robert
Kcam Cut depth 47MLB Kellyware CAM 6 01-18-2012 01:04 PM
rotary 4 ax depth of cut q. nervis1 Mastercam 4 03-24-2005 04:34 PM
cut single, cut auto and cut all??? fastolds BobCad-Cam 3 10-06-2004 08:15 AM
PICS - BOAT HULL CUT WITH CNC ninewgt DIY-CNC Router Table Machines 16 08-02-2004 06:21 PM
Can you cut Al. with a wood bandsaw CactusChip General Metalwork Discussion 5 11-20-2003 03:45 PM
