Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > GRZ Software- MeshCAM
GRZ Software- MeshCAM Discuss GRZ Software- MeshCAM software here.
Old 04-22-2005, 01:34 PM
Ursine is on a distinguished road
MeshCam question
In MeshCam I can see where I can engrave a shape into a material, but how do I cut out a shape along it's outline?
Thanks,
Dave
Old 04-22-2005, 09:11 PM
Mac T. Knife is on a distinguished road
Tabs. When I create a model, I include tabs to hold the piece to the existing stock so it doesn't come loose from the clamps. When setting the stock material settings, I increase the stock size that Meshcam defaults to so that I can machine the sides of the piece.
Old 04-24-2005, 06:57 PM
ger21's Avatar
Thanks,
Dave
MeshCAM won't cut the part outline. But, like Mac says, increase the stock size by at least the tool diameter and it will cut all the way through around the perimeter. I think the next version will make this easier, but it still won't cut the outline. That's just not what it does. If you want to cut flat parts by just cutting the profile, look at SheetCAM.
Old 07-01-2006, 06:54 AM
zoltan is on a distinguished road
Can somebody, please, tell me how I can setup mm in Meshcam 2 instead of default inches?
Thank you.
Zoltan
Old 07-01-2006, 03:38 PM
robgrz is on a distinguished road
When you load a model select MM rather than inch. All parameters in dialog boxes will accept either if you follow the number with either "in" or "mm." Finally, the output is converted to in or mm based on the post processor you choose. What post do you select?
-Robert
Extremely basic machining question. touser General Metalwork Discussion 9 06-19-2005 12:51 AM
Question about power supplies dowling177 General Electronics Discussion 1 01-28-2005 07:01 AM
meshcam question senor J. GRZ Software- MeshCAM 1 10-22-2004 09:40 PM
Hobbycnc controler question chas Hobbycnc (Products) 3 09-09-2004 05:00 PM
HF lathe question rs1300 General Metal Working Machines 0 01-19-2004 11:22 AM
