Unexpected Results
Results 1 to 2 of 2
Thread: Unexpected Results
    Jul 2017
    Default Unexpected Results
    I am working on a carve that I thought should be fairly straight forward, but for some reason am not getting quite what I expected. Here’s a picture of the model, using MeshCam to generate the toolpath. And also a picture of what was carved. Ultimately it will result in the correct final product, but seems like it is working harder than it needs to. It makes two rings in the hole, one is the outer that will be the correct final product. I’m confused by the inner ring though. It seems like this is making a nicely finished inner piece, but that piece is actually just scrap, I only care about the hole. Is there maybe a setting that can get rid of that? Or an explanation as to why it happens? Seems like the overall carve should not take as long if it’s not making that inner ring. Any advice would be appreciated! Thanks!
    Attached Thumbnails Attached Thumbnails Unexpected Results-screen-shot-2017-10-20-12-08-a   Unexpected Results-img_3492-jpg   Unexpected Results-img_3495-jpg
    Dec 2006
    Default Re: Unexpected Results
    Upon first look, it looks like there is a ghost element that has an associated tool path. Or, you have some offset to your tool path?
    Good Luck
Unexpected Results
Unexpected Results
