The smoothing will smooth out the surface but outer contours may have some jaggedness if the source image had it or if the resolution is too low. When you calculate a toolpath, the contours are offset outward and this tends to smooth out the finished part a lot.
If you're at 100DPI then it's unlikely that your cutter will be it possible for a little .01" jag to show up in the finished part.
-Rob
