removing stock too early
Results 1 to 5 of 5
Thread: removing stock too early
    Jul 2014
    Question removing stock too early
    Hi there,
    so, I am using the trail version of meshcam and I tried to convert this object to gcode:
    removing stock too early-9l8ibyq-jpg
    As you can see, I set the stock size a bit bigger than the object itself. I did this because I want to cut this piece out of a bigger piece of MDF wood.
    My problem is that the gcode of meshcam first cuts the piece out of the bigger stock before it machines the inner part. How do I change this sequence?
    Thanks.
    Jul 2007
    Default Re: removing stock too early
    Meshcam isn't really the best program to use for this. It's strength is true 3D while your part is 2.5D. A 2.5D CAM such as CamBam or SheetCam are much better suited for this part.
    bob
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    You can set machining regions and output separate g-code for the inside and outside portions.
    UCCNC 2017 Screenset
    Jul 2014
    Okay, thanks both! I just got back from holiday and tested cambam.
    When I load the same stl file in cambam and produce gcode, I get this path:
    As you can see, it wants to turn the complete internal rectangle into dust by milling everything. I have no idea how I can let it just cut out the border of the rectangle. Does anyone of you know? I don't want to draw this object with cambam itself.
    I hope it's not a problem that I ask this question in here. Otherwise, sorry .
    Jul 2007
    It looks like you specified a pocketing operation for the inside. Use a profile operation and it should work fine.
    b0b
