| Group Projects This forums is where things can be ironed out, tasks allocated, task feedback made. |
#49
I use windows all day every day and roundly curse it at least every hour. Funny thing about democracy... Its the only "system" that by definition, allows other "systems" to also be acceptable. Best |
#50
| Has anyone considered using an FPGA? Check out this board for $99: http://www.digilentinc.com/info/S3Board.cfm It's just a matter of using the Xilinx tools to create the software. I just finished a course at cal state where we designed a 16-bit RISC processor and loaded it into the FPGA. This thing is great too because it has VGA out and a PS/2 port. So you could have a monitor and keyboard.
__________________ Andy CNC Kits - http://www.comptonsoft.com/cncweb/ |
#51
| Hi, I am looking for a (reasonably) economical way to run a "planned" 4 axis mill / router. (hobby use) I am very tempted by Rhino, which is win based, so it would be handy of course to use the same computer for the control as well. I found these motors http://www.imshome.com/mdrive42acplus_mdi.html which can plug right into a USB port and AC. IMS provides some control software (m code) as well. I have no experience at all with G code / cnc yet, so wide open to various approaches. I am just curious if there is a way we can use something like this to simplify our life of making a CAD to CAM arrangement. |
#52
| Hi Guys, I have been watching you guys talking about G-Code Interpreter. Some one opting for DSP and some one for PIC, and of course some people being scary about PIC will not do, DSP will do, what about circular interpolation. Good news for every one that I have implemented linear and circular interpolation in a PIC, yes PIC18F458/PIC18F452 running at 40MHz and I have made some STARS of various corners and aspect ratio, and some round shapes, rectangle with sharp corners, and recatngles with round corners too. In both metric and inch units. I will soon be posting the schematic and the test code in hex format for you guys to test. Once I finalize the main interface cause right now I have graphic LCD 128x64 KS0108 based controller, and a 4x3 keypad installed. I am going for 240x128 T6963C based LCD and some really serious input interface for it to represent my work piece. Later I am planning to decode the following mostly used G-Codes in the PIC18F458/452 G00 positioning (rapid traverse) G01 linear interpolation (feed) G02 circular Interpolation CW G03 circular Interpolation CCW G04 dwell, a programmed time delay G20 input in inch G21 input in mm G90 absolute dimension input G91 incremental dimension input Till then Regards for every body on CNCZONE |
#53
| An exact stop trajectory planner is not hard to implement using any hardware or software. By that I mean that the machine comes to a full stop at the end of each move, and so it also starts all moves from a full stop. The trick (if you want to do 3D moldmaking or complex paths in general) is to make a trajectory planner that 'cuts corners' within a specified tolerance and keeps up the velocity of the machine. That is nontrivial, and I'd be delighted to look at any open-source implementations anyone has come up with. I've tried to understand how it's done in EMC2, but really going through the code and math requires more time than I have right now... |
#54
| This also sounds a lot like what the NCPod (www.oemtech.com/ncpod) does, although it seems to have been in beta testing for quite a long time. Does anyone know the status of the NCPod? |
#56
| Ok, so I'm yet another guy who is interested in this idea. I've got some code partly done that does the 3 d line to step and direction thing, but also managing ramping and acceleration. The code is at https://docs.google.com/document/d/1...t?hl=en&pli=1# And I'd love to have some feedback on it. If space and time allow, I'll add a very limited G code interpreter to it. |
#57
| Hi everyone,I am new to the forum.I am doing my final year project on CNC and i want some guide line from u guyz. 1.Can g-code be converted to hex file? 2.And if so than which microcontroller is best to use(PIC or AVR) |
#58
| techref.massmind.org/techref/ascii.htm but that wouldn't do anything for a uC unless you find a program to load into the uC (usually in hex format) which can interpret the g-code and signal drivers to drive motor to move a CNC machine. This page might link to what you are looking for (in the "See also" section) techref.massmind.org/techref/io/embeddedCNCs.htm |
| Autocad to gcode | JamesMI | Autodesk Software (Autocad, Inventor etc) | 17 | 12-02-2011 02:54 AM |
| turbocnc and cams gcode | Lu_ca | TurboCNC | 1 | 07-12-2006 06:50 AM |
| Is it possible to get a gcode into Rhino | MrBean | Rhino 3D | 11 | 04-03-2005 07:41 AM |
| gcode to gcode converter | july_favre | General CAM Discussion | 4 | 05-24-2004 06:51 PM |
| Gcode verify autocad plugin | balsaman | General CAM Discussion | 1 | 10-31-2003 11:22 AM |
