| Granite Devices Discuss about servo & stepper drives made by Granevices and get direct support! |
I purchased 4 x VSDE drivers a few months ago. I Have just recently finished wiring up a custom built 4 axis lathe and have begun to iron out the issues. I have 3 x 180 Volt PMDC motors they are 4 pole and are working perfect. I have 1 x 200 Volt (7amp peak) BLDC control techniques motor with 24 VDC brake and its having a few issues. Ive gone through and set it all up...... It begins to turn and makes about 10 full rotations then it just feezes and doesnt go any further. Ive tried a few other VSDE in its place to confirm it wasnt the driver and they all do the same thing. I was wondering how far down the road your firmware is for the BLDC motor or does it have some bugs. If I was to take a guess from limited knowledge it appears as though the phases are swapping to begin the rotation but the timing goes out and causes the motor to stall. I have a 1000 CPR encoder on the top which has been tested and works fine. I can see the counts going up and down correctly in yoru diagnostics section. of GDTOOL. |
| Hi, That kind of "freezing" may happen with synchronous motors (BLDC or AC) by two reasons: 1. Encoder count is not set exactly correctly in drive parameters 2. There is some noise in encoder signals so drive loses some encoder counts and eventually motor goes out of sync The most probable case is #1. Are you sure your encoder is not for example 1024 CPR instead of 1000? |
| According to the shipping sheet from US digital it is a E5-1000-250-I-S-D-D-B Ive checked the website to make 100% sure.... 1000CPR with 1/4 inch bore. Single ended output. I suppose noise is an option being a single ended output. |
| Ok, Please test if motor can you rotate motor in opposite direction when it has frozen. You may need to help it by hand to make first revolution (this may be needed because torque can go to zero if motor is out of sync). Or can you rotate motor within +/- 5 revolutions infinitely? If it's very repeatable, then it's bit strange to be noise. You may also check encoder line count from encoder disc directly (in case of usdigital error). |
| From mach3 i can turn it back and forth without the use of my hand. I can only do this for a few spins in each direction until I get a complete lock up. Sometimes the card goes into a blue light with red green flash sometimes it just stays blue but I lose control over it. I had a filter put onto the encoder side and scoped it again the voltages seem to be very clean. Upon checking out the encoder settings and running the motor drive test the faults coming up are; 2615 ish encoder counts detected and 4 poles. 4 poles is 2/3rds of the poles being a 6 pole motor and 2615 is about 2/3rds of the PPR count. I placed this motor back on my large mill shortly after and it cranked first time again without issue. I did take a backup of the config file using gdtool which I can send if you could be of any assistance. I also have remote access into my machine and camera setup on it. |
| Here is what you can do to verify number of encoder counts: Turn down HV supply and turn motor exactly 5 turns by hand (place/draw some mark on shaft to get precise revolutions) and see how many counts the GDtool counter changes. With 1000 PPR encoder value should change almost exactly 20000 counts. If it's closer to 20480 then you have 1024 PPR encoder disk. |
| When I issue rotation commands from mach3 I watch the encoder counts in GDTOOL it manages to make it to around 8500 counts in either direction before it starts to stutter. As long as i stay between -8200 to +8200 I can spin the motor back and forth all day long. Incedently the encoder counts before error is set to its max of 16344. |
| The GDtool is not at the moment designed to be used simultaneously with other control sources (it may work, though). Try unplugging CMD cable from drive and using USB adapter thru GDtool only. In your case can use moveinc 4000 commands in event log to rotate motor one revolution at a time. That way you can see if it turns full revolutions. If not, then the encoder signal quality (maybe shielding) is the problem. |
#11
| So it is encoder signal problem. Have you used shielded cables the way VSD-E manual figure 12 suggests? Have you also connected also motor frame to drive FG? There are rumors that some USdigital encoders are extremely sensitive to noise (possibly by defects). Several CNCzoners have had troubles with them (also with Geckodrives, UHUs etc). You may search about it. Some of them had to purchase another kind of encoder to solve the problem. |
| BLDC voltage ? | Juka | Servo Motors and Drives | 6 | 09-08-2009 07:31 PM |
| BL and BLDC? | 15mgtar | Servo Motors and Drives | 24 | 08-18-2009 08:11 AM |
| Regarding Transferfunction of BLDC Motor | pathamuthu | General Electronics Discussion | 1 | 01-27-2009 02:30 PM |
| BLDC with EMC2 | katti | LinuxCNC (formerly EMC2) | 14 | 11-05-2007 06:45 AM |
| BLDC control software | t305100 | General Electronics Discussion | 3 | 08-25-2006 06:36 PM |
