| Granite Devices Discuss about servo & stepper drives made by Granevices and get direct support! |
| Hi there, I'd suggest you get an encoder with a finer resolution as this will give better motor control and higher accuracy, then use the pulse multiplier in GDTool to make each input pulse = 0.001" and turn on the input pulse smoothing. Best regards, Jason |
| So sorry - if you get an encoder with 250 lines per inch, it will be 0.001" resolution after 4x decoding, so one input pulse from your control will result in a move of 0.001" assuming the multiplier in GDTool is set to 1:1. However, I have been wrong about the quadrature decoding before, so if I am wrong again, hopefully Tero will correct me and give you a definitive answer! Best regards, Jason |
| Hi, 250 cycles/inch will give you a resolution of 0.001. However, you generally want an encoder resolution many times higher than the positioning resolution that you're aiming for. In the above case with 0.001 resolution the motor can be 0.000999 from target position without the drive knowing about it. If you're aiming for 0.001 resolution "at the mechanics" then go for 1000 cycles/inch scales - at least. |
| Need Help!- "motor steps per resolution" and "driver microstepping" settings | margni74 | LinuxCNC (formerly EMC2) | 9 | 10-24-2009 02:33 AM |
| need help using vsd-a with linear motor | daedalus | Granite Devices | 7 | 05-28-2009 07:01 AM |
| Just saw a linear motor XY table with linear encoders today...nice | guru_florida | General Metalwork Discussion | 6 | 04-28-2009 07:39 PM |
| looking for a linear motor | fargo_182 | Linear and Rotary Motion | 4 | 01-23-2009 01:32 AM |
| Stepper motor resolution | Adamx | Tormach PCNC | 2 | 10-26-2008 06:37 AM |
