| Granite Devices Discuss about servo & stepper drives made by Granevices and get direct support! |
Finally- I am able to move my plasma cutter. After I was able to move the servos, and the overcurrent faults stopped happening, I decided to re-installed the VSDEPI board. It also works!!!! Nothing moves until I tell it to. All the e-stops work. All the limit switches work. The last item is to order new encoders. I ordered the 1250 cpr encoders, because I planned on using the SmoothStepper, but stuff changed. I am using the BOB from Candcnc.com, because the digital torch height controller. I am thinking about ordering some adjustable encoders from AMT. Is being adjustable something I need? I am just checking all options before I spend even more $$$. Once my ballscrew gets delivered, I will upload a video of it moving. Steve |
| I'm not sure what drive you are using, but I saw in the VSD-E manual there is a built in step multiplier/divider (1 to 32767). That should allow you to use the encoders you already have, shouldn't it? Steve - complete newbie here, just looking into new VSD-E drives... |
| Congratulations Steve! I'd be glad to see the video once ready ![]() Use VSD-E scalig to overcome the limitation of CNC software step pulse frequency. Servo benefits from high resolution encoder. So if you have adjustable encoder, set its resolution to maximum, and if necssary adjust drive scaling to achieve full speed. |
| Xerxes, Please post screen shots of settings and detailed instructions on how to adjust drive scaling. Thank You Jeff...
__________________ Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish. |
| Ok- Time for an update. I have everything moving, but if I move it to fast I get "Following errors" The video that I uploaded is running about 300 ipm. I have the following errors set at 1000, does anyone know if that is a good number or should it be set higher? In the trajectory planner, I changed the ratio from 50 : 50 to 300 : 100 http://www.youtube.com/Scrambled1981 Steve |
| Nice video! 1000 should be enough, so the problem is elsewhere. Try doing fast moves under GDtool to find out why the error grows so much. You can use moveinc somevalue command in Event log to move motor manually. Two most common reasons: -Position controller gains need adjusting -Supply voltage is limiting motor speed |
| Tero- When I tune my Servos, should I have the pinions engaged into the rack? For the supply is limiting the voltage, I am using 3 1000 watt power supplys from Anteck, and all three are tied together. Would I need to install a large capacitor? Steve |
| Need Help!- Slow G02 / G3 moves | ronateah | Mach Software (ArtSoft software) | 4 | 10-11-2009 08:00 PM |
| Need Help!- UCS moves from Autocad | Timvmax | BobCad-Cam | 2 | 09-08-2009 03:20 PM |
| Need Help!- unwanted z moves | Claude Boudreau | BobCad-Cam | 12 | 03-18-2009 03:20 PM |
| Need Help!- G54 X-axis moves?? | Florida Ted | Haas Mills | 8 | 03-14-2009 11:09 PM |
| Need Help!- Getting some bad moves. | Stampede | BobCad-Cam | 1 | 09-26-2008 07:47 PM |
